Upgrades (2000 Civic Si)
Old Mar 15, 2007
TheDrizzle50's Avatar
TheDrizzle50 is an unknown quantity at this point
I want to know what road to take in upgrading all the internals of my car. From cheapest to most expensive first.
[x] Cold-Air Intake (Replaced the short-ram) - $200+
Thinking about headers as the next step? $400+
-- Then maybe a turbo? $1,000+
Any recommendations?
Old Apr 19, 2007
si_ya's Avatar
si_ya is an unknown quantity at this point
Re: Upgrades (2000 Civic Si)
Thinking you're going to spend 1k on a turbo is an awful idea. If you do a turbo, you have to do it correctly. You can't half *** it because then you'll be dropping more money into your car than you had ever imagined. I did a K-swap and dropped 12k on it...Prior to that I had a full (street) turbo kit that totaled me at about 7k. I would just save your money for a quality build and not waste time and energy of looking at a turbo in the 1k range man.
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
i just sold my 90 integra (DA) 4dr. with a b16 swap, this is what i did
head & intake manifold port and polish, JE frogger throttle body, type-r cams, every moving part from the head gasket up was changed to type-r, dc header w/ drag heat wrap, full 2 1/4 inch straight pipe header back exhaust, injen cold air intake w/ arospeed mushroom filter, i converted from obd-0 to obd-1 for better tuning, ive always noticed that obd-1 is better than obd-0 or obd-2a/b to tune, vtec controller, ballenced pistons rods and crank, this made it so i could get light weight pullys and balencer because there was no vibration, msd ignition, i put in b20 injectors but i dont know if it made a diff., AEM fuel rail and regulator, type-r water pump, a chipped ECU and a chrome valve cover lol, thats all that comes to mind and i had the 160hp 111tq at the flywheel b16 and i got it to 197hp 134tq of 100% untuned power to the ground and i could rev to 10,000 but i never did, id take it to 9000ish and got scared because i put to much $ in it to blow it up but the kid i sold it to bounces off the rev. limiter all day long and all he had changed was the cam seals...., i got pics via myspace search e-mail mrkevindshore@yahoo.com
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
