How to aim 01-03 headlights?
Old Jan 30, 2007
blouisgod's Avatar
Life Begins > 6800rpms
yeap, after touching them about 1 million times, I asked. Well, I dont have them infront of me.
Old Jan 30, 2007
D5cIvIc's Avatar
check your manual. But there should be a slot on top of your headlight that you can turn with a screwdriver.(if you have a coupe) i believe a sedan has an adjustment **** that can control both horizontal and vertical aim.
For a coupe. it should be right on top. There should be a little hole where you can put a phillips through to turn the little **** inside to aim the headlights. hope that helps. I got no pics to show you, but check your manual. it will tell you in there
Old Jan 30, 2007
Alpha 5's Avatar
Here it is right out of the factory Honda service manual.
Old Jan 30, 2007
Old Jan 30, 2007
burke420's Avatar
The World Is Yours!
so gearbox...is that fo the sedan or the coupe?
Old Jan 31, 2007
D5cIvIc's Avatar
coupes are a little differnt. the one gear has is form a sedan. The coupes ones is like a little plastic **** that has to be turned with a phillips
Old Jan 31, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
yea for the coupes theres a little arrow where u have to slant a phillips head into it and turn. The hole has a U <--> D on the top of it Cant miss it if u just look at your lights
Old Jan 31, 2007
blouisgod's Avatar
thanks guys, ill do that tonight.
AyyeeGeorgee
Sep 14, 2015 12:54 PM
shaejb15
Sep 12, 2015 01:02 AM
Ultra Havoc
Sep 9, 2015 10:58 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
