$500 to replace o2 sensor???
Old Jan 16, 2007
jester458's Avatar
jester458 is an unknown quantity at this point
so my friend took her 98 civic dx to the dealership cause she got a cel. they pulled the code and it was P0141 which is "O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)"
they said both of her o2 sensors need to be replaced, and it will cost a little over 500 dollars. ($210 and $185 for the 2 sensors, plus 2 hours of labor.) it sounds rediculous to me, but 2 questions come up.
do the o2 sensors even need to be replaced?
should it cost 500 bucks?
any help would be good, cause i know nothing about civics.
thanks a lot
Old Jan 16, 2007
jester458's Avatar
sorry i'm a dumbass and posted this in the wrong generation thingy. the right one is in the right place now and i cant figure out how to delete this damn thing. so if an admin wants to, go for it.
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
Yes, they need to be replaced approx. every 50k miles, it all depends on how you drive it. Yes, they are rediculously expensive, and yes, it will cost about $500. I have to replace mine and its going to be almost $500 just for the sensors....if you want to save some money...do it yourself. Its really easy.
Old Jan 16, 2007
Rufus's Avatar
I have an extra off of an 03 lying around somewhere...
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
Well, I dont think those are going to work for a 98 though.
Old Jan 16, 2007
jester458's Avatar
if i were to replace the sensors myself...
are they easily accessible?
do i have to F* with the wiring (any splicing or whatever)?
and do i need to replace both of them even though the code (from my understanding) is only describing a problem in one of the sensors?
Old Jan 17, 2007
spoonEM's Avatar
omgwtfbbq mod.
Well, since its only reading 1 code, then its only one sensor. SO, you need to get that sensor, unscrew the bad one from your exhaust pipe (location will depend which one it is), unplug it, screw in the new one, plug it back in and your done. Its not too bad.
Old Jan 17, 2007
jester458's Avatar
so then the shop is just being a **** when they say that it will take 2 hrs, and they need to replace both o2's? thats what i was originally thinking on this one.
Old Jan 17, 2007
spoonEM's Avatar
omgwtfbbq mod.
Well, heres what to do. Head to Auto Zone, grab their code reader, and see what codes are coming up. If both 02 sensors are bad, it will read AT LEAST 2 codes. When I did my motor swap, I had the wrong sensors in (01-03 dont work in 04-05) and it read 4 codes. Swapped them out, and its only reading 2 codes because one of the sensors is bad. NOW, on the 98, Im not exactly sure, but if it says bank 1 sensor 2, Im thinking its the secondary sensor which is the one right after the cat. Even if the shop had to replace both, it doesnt take 2 hours, unfortunately, they will charge you flat rate hours, which 2 hours is about normal for that.
Old Jan 17, 2007
jester458's Avatar
alrighty. thanks a lot for your help. at least i now have an idea of some things to check out on her car. and then when i'm done figuring out stuff on her car i can go back to driving my WRX
Old Jan 18, 2007
GNX423's Avatar
GNX423 is an unknown quantity at this point
as a reference check this out:http://www.partsamerica.com/ProductL...=Oxygen+Sensor
looks like the pre-cat sensor (should be in the exh manifold) is reasonable for just under $100. the pre cat is the one one that really does anything, adjusts the a/f ratio. the post cat just checks the condition of the cat for emissions purposes, which should be a p0420 i belive.
Old Jun 25, 2007
mclean987's Avatar
mclean987 is an unknown quantity at this point
Re: $500 to replace o2 sensor???
still got it ? pricE?
Old Jun 28, 2007
BLK03EX2DR's Avatar
BLK03EX2DR is an unknown quantity at this point
stealerships get their name for a reason. you can buy a plug and play HO2 for around 80 or so depending. you can also buy universal sensors and splice them yourself to save a few. hell you only really need the front one, the second one is just an emmissions monitoring device.
Old Aug 17, 2008
ugabuga's Avatar
ugabuga is an unknown quantity at this point
this is crazyness. I got 2 brand new DENSO sensors (same as OEM) for $90 shipped from rockauto.com.
Then it took me all of 30 min to replace both (you need to have a 02 sensor removal socket for your ratchet).
$500 is a rape
JetsterDajet
52
May 8, 2016 12:11 AM
jdh022764
18
Nov 3, 2015 06:44 AM
Bruce2
Sep 21, 2015 08:01 PM
2.0.0.2
Sep 14, 2015 06:38 PM
dantheman42
Sep 4, 2015 01:10 PM
