fuel relay clicking
Old Jan 2, 2007
tweeder's Avatar
tweeder will become famous soon enough
fuel relay clicking
I have a 01 civic ex i was cruising down the road when the engine died. Now when i start up the car it sounds fine however you can hear the fuel pump relay click about a dozen times. Then, the engine goes into a semi limp mode where the tach shuts off and the engine will not allow you to give it more than 10% fuel. My a/f gauge shows the car leaning out when you press down the gas, which tells me that whatever controls the deadhead fuel system is not increasing the amount of fuel pressure coming out of the fuel pump. So why does the relay click, is it bad? Or is the fuel pump bad? But why would the tach die. I have read up on other posts and the only thing that I have seen is cleaning out the IACV. I will probably try that tonight unless I here something from one of you.
Thanks in advance.
tw33d3r
Old Jan 2, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
the relay went bad... change it.
Old Jan 2, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
change it. even if it isnt the problem, its like the 2nd cheapest place to start. i usually swap all vital relays on a regular basis so i dont have little suprises like this. ive got a pile of relays in my shop. probably nothing wrong with a single one, but im not going to be standed.
Old Jan 2, 2007
sql_civic's Avatar
I've had this happen to me and it turn out to be an engine harness ground wire on my 98 Civic. This wire connected to the thermostat housing. Check the ground wire to your battery and any others that you know of or have been messing with recently. Don;t just wiggle the connection, take the wire off and clean the contact good.
Good Luck.
Old Jan 2, 2007
then do a ground wire upgrade.
Old Jan 6, 2007
tweeder's Avatar
well I bought the relay, shipped from tenn to ohio cuz no one keeps this one in stock. It didn't work. I will start looking over ground wires.
Old Jan 6, 2007
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
I dont think it is the ground, but i would actually go ahead and change the fuel pump..imo
Old Jan 6, 2007
tweeder's Avatar
well i've port n polished my head and have a full header back exhaust, I have a e-manage but had trouble installing it and held off for a while. So running on stock fuel setup could I have f'ed my fuel pump? But what about the tach dieing out? This has to be some sort of electronics.
Old Jan 6, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I had a simular problem, turned out the be a dicked up ECU
Read my thread about it here..
Goodluck
Old Jan 6, 2007
tweeder's Avatar
yeah thats what I figured
alxz310
Jul 30, 2015 12:18 PM
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
fvckbg
Jul 7, 2015 07:08 PM
ZILLA
Jul 5, 2015 05:24 PM
