Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
Rev limiter
Old Feb 1, 2006
imported_Mikey's Avatar
imported_Mikey is an unknown quantity at this point
Rev limiter
Does anyone know what the rev limiter is set at in the 2000-2002 Si civics?
Also, how does one remove the limit?
Old Feb 6, 2006
Frantic's Avatar
Frantic is an unknown quantity at this point
7500 isnt it?
I imagine its ECU related, you might need an overriding chip to remove the rev limiter (then again it could be a flick of the switch somewhere, Im not 100% sure).
Old Feb 6, 2006
Tayler's Avatar
Tayler can only hope to improve
Im pretty sure its a ECU thing(not positive), be careful if you do mess with the rev limiter because to much rev on a stock motor can do damage to it.
Old Feb 7, 2006
vtec12's Avatar
vtec12 is an unknown quantity at this point
Its a Honda though, surely it can rev to 9000rpm and still be happy?
Just kidding Mikey.. dont do it unless you have a worked vtec motor
Old Feb 13, 2006
Albaniancivics's Avatar
Albaniancivics is an unknown quantity at this point
doesnt metter what it is, the si engine doesnt rev more then 8k, if u remove the rev limiter u will blow your engine not by the first try but u will blow it in like a week
Old Feb 14, 2006
TomH's Avatar
TomH is an unknown quantity at this point
So no point removing the rev limiter, you're not racing on the track!
8000rpm is more than enough road use. hell i used to have a car that wouldnt rev past 4000rpm and i could still drive it ok.
Old Feb 19, 2006
Ok thanks guys.
I really had no idea what to do there, thanks for the advice
I think I will just leave it as it is to be safe.
Old Sep 26, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
Just Looking Through Some Old Posts, Is Everyone Aware That There Was No Si In 2001?
The Coupe Was A 2 Year Deal 99-2000, And Then The Hatch (ep) 02-05
And Then We Got The Current Fg2 Coupe Si
And 99-00 Si Revved To 7800
Old Oct 25, 2006
shortround's Avatar
shortround is an unknown quantity at this point
+1. These are two different cars. My 2000 si redlined at 8000 and went just slightly pass that before hitting the rev limiter. I have no idea what redline was for the 2002 lunchbox.
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
carid
Sep 28, 2015 10:13 AM
99BoostedSi
Sep 7, 2015 04:49 PM
