Emergency! Tie Rod Warped
Old Dec 14, 2006
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
The one thing I feared most has happened. The tie rod tread was warped from me banged it to get it off the strut, im putting on new struts. Since the bottom end of the tread is warped, I had to use force to screw it on, when I did this I noticed the whole tread was moving along with the screw! So I guess I broke it off or something inside. What the hell do I do? I got it as tight as I could by holding on to the tread with pliers, but the screw only went up a little, I haven’t got it passed the hole that the cotter pin goes in. How am I going to fix this? I have to move the car, can I at least drive it a little or is that to risky?
What do I do? This sucks big *** *****.
Am i just going to have to buy a new tie rod end? If so do i just get Part # 8?
Old Dec 14, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
ooo man good luck. i had the same problem i put a oem jack to wedge the screw in ans then i just kept trying and trying. it literally took 2 hours just to put the nut on. and no do not drive it. i dont know what else to say.
Old Dec 14, 2006
SevenCyrus's Avatar
I see, ill try that, grease is leaking out of the boot now, lol. I tried taking the tie rod end off as well, that **** is ****ing hard.
Old Dec 14, 2006
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Don't double post please and I replied you in the other thread.
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
