What should I use for an intake tube?
I have a stock '02 Civic Coupe EX 5-spd. I recently put in a K&N drop-in filter to the stock airbox. I like the results and the car has a *little* more pep around 5-6kRPMS. Not a huge difference, but noticeable. The old filter was a stock Honda filter that was new and clean.
I want to remove the resonator to see what it sounds like and just to see if it feels any different while driving. Don't worry, I'm not expecting much of a difference in performance, if any. I realize it will probably be just a difference in sound. I do not plan to purchase a CCA or SRI, or upgrade the header or exhaust.
I want to install a DIY tube or hose to go from the stock airbox to the same stock air pickup location by the battery. I'm looking for recommendations on what material to use for the intake tube/hose, as well as the inner diameter.
I know the tube/hose should be as smooth as possible on the inside, with as few bends and turns as possible.
Should I use a metal like aluminum, a rubber hose, or a plastic/pvc tube?
Should I use 2.5" inner diameter or 3"?
Also, does anyone know what size the inlet fitting to the stock airbox is (3"?)
Thanks for the inlet size. I'll probably stick with 2.5" i.d. then.
I'm wondering which would be best at keeping the air coolest through the hot engine compartment: pvc, plastic hose, rubber hose, or aluminum pipe.
K&N makes their cheaper CCA and SRI from aluminum, but makes their most expensive FIPK II from a plastic. But AEM uses just aluminum.
I know this is not crucial or anything. It just seems like since this is almost free, I might as well pick the material that would resist the heat the best or get rid of heat the fastest. Why does AEM use aluminum but K&N use plastic for their top of the line intakes?
abs plastics and composite carbon will keep the most heat out/ambient temps in. i think the fipk is a carbon composite. metal will absorb the most heat. i have a sri, but i built a heatshield out of two pieces of stainless steel that i tacked together with air ventalation between to insulate the pipping. it makes about a noticable degree drop from engine to filter. but that takes time, which you don't seem to have....also my first civic i took a coffee can and opened both sides, strapped a 13 inch k&n to it, and hose clamped it to the TB. it was sweet and super loud!!
Either heat shield or thermal wrap will help keep the temps down. As stated above, plastic seems to have better ability to keep hot air outside and cooler air inside, and metal heats up (and cools down) faster.
And for:
Um, no. Neuspeed or DC Sports strut bars will clear an intake.
And for:
WTF?? I feel like Sujak. I'm all pissed off. I don't even know why, but this is the stupidest thing I think I've ever seen on this site. Shop vac hose?? It looks too small. The ribs on the inside are going to make it even harder to draw air through. You will negate that .025 HP increase you got from taking off the resonator by suffocating your engine. And the hose sticking out where the fog light should be looks ghetto as hell. If you're not going to put an actual intake on there, you should have left everything stock, or just removed the resonator and called it a day. 7th gen civics are decent cars. You should not be half assing your car like you would a 1991 Hyundai you're trying to keep running without investing any money. While you're at it, why don't you make yourself a lip for the front out of landscape edging??
It might work better if you took the shop vac motor unit, duct taped it to your bumper, and then connected your home made cold air intake to the exhaust/blower connection on the shop vac. It would be like an electric supercharger.
/sarcasm
/sarcasm
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 06:48 PM
