Amp draw for '04 EX sedan moonroof switch?
Racism sucks, just like your Mom...
I did my obligatory search, but no luck...
Does anyone know what the amp draw is on a moonroof switch for a 2004 EX sedan? I'm doing a mod that'll relocate control of the moonroof to some buttons I'm installing in the headliner by the moonroof, itself. Problem is, I need to know what the OEM switch handles for amps, so that I can be sure to get the equivalent for my new switches.
I have some picked out, but I need to know before installing everything, so any help would be appreciated. Thanks...
The switch passes ground directly to the open relay and the moonroof limit switch. The limit switch passes the ground to the close and open relays. The other side of both relays is a circuit fuse to 7.5A. I'm sure switches that can handle that current will be fine. Diagram included:
christmaspie, you rock!!! Thank you for finding that info!!! I really appreciate it...
I checked out your ride. Nice setup! Just one quick question: the blue LEDs at the hazard light and door---what are they for?
CiViCPrAnInG2k1
Dec 6, 2001 08:58 PM
