Amp draw for '04 EX sedan moonroof switch?
Old Dec 4, 2006
Scott Civic's Avatar
Racism sucks, just like your Mom...
Scott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of light
I did my obligatory search, but no luck...
Does anyone know what the amp draw is on a moonroof switch for a 2004 EX sedan? I'm doing a mod that'll relocate control of the moonroof to some buttons I'm installing in the headliner by the moonroof, itself. Problem is, I need to know what the OEM switch handles for amps, so that I can be sure to get the equivalent for my new switches.
I have some picked out, but I need to know before installing everything, so any help would be appreciated. Thanks...
Old Dec 5, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
The switch passes ground directly to the open relay and the moonroof limit switch. The limit switch passes the ground to the close and open relays. The other side of both relays is a circuit fuse to 7.5A. I'm sure switches that can handle that current will be fine. Diagram included:
Old Dec 5, 2006
christmaspie, you rock!!! Thank you for finding that info!!! I really appreciate it...
I checked out your ride. Nice setup! Just one quick question: the blue LEDs at the hazard light and door---what are they for?
Old Dec 5, 2006
No problem man, those three LEDs are for my alarm.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Lopes101
Jun 7, 2015 08:04 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
CiViCPrAnInG2k1
Dec 6, 2001 08:58 PM
ImmortalEX
Dec 1, 2001 09:51 PM
