Need help with box size
Old Nov 26, 2006
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I built a box for my friends truck ... the subs need 6 cu ft but the box ended up being about 10 cu ft because of the placement of the subs. Theres no way around it so I was just wondering what you can put inside that take care of the 4 cu ft. Cotton? Help me out. Thanks.
Old Nov 26, 2006
LudlamTheory's Avatar
i boogie for the raindrops
10 cubic feet?
what kinda dimensions?
Old Nov 26, 2006
d17acivic's Avatar
d17acivic is an unknown quantity at this point
woah! thats a big box
Old Nov 26, 2006
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
That box sounds huge. What's his setup gonna be?
Old Nov 26, 2006
vietfob714's Avatar
4 15s its 49" x 22" x 17" Need to fill up 4 cu ft. Dont know with what... i thought cotton would work but everybody says that makes the sub think the box is bigger
Old Nov 26, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
can you not chamber it off and leave gaps between each chamber on the inside of the box? it will be just sealed off space. make 3 1.3 cubic feet boxes to place inside the box between then chambers. so it will be sub, 1.3 cu ft box, sub, 1.3 cu ft box, and so on. if youre doing a ported box youre going to have to just seal off some room on the inside back wall or something.
Old Nov 26, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
im sure a box that big could use some bracing, that counts toward reducing the box volume
edit: if its a sealed box dont worry about being dead on, a sealed box can vary by upto 30% with no noticeable decrease in output
Old Nov 26, 2006
well the 1.3 cubic foot boxes will brace the **** out of it.thats gonna be one heavy system.
Old Nov 27, 2006
those internal or external dimensions?
if external, thats only 8.7 cubes.
bracing is definitely a must
also remember, each sub will take up about .25 cubic feet because of its motor structure (at least if its a big 15)
so if its internal, were down to 9 and change
external, were down to 8 flat
youre definitely gonna want bracing on the baffle, but bracing isn't gonna offer you much displacement, unless you box off areas.
what youre gonna want to do is box off some areas inside the box
either that, or port it
what kind of 15's are these?
and could you by chance give me a picture, i might have some interesting design ideas for you
Old Nov 27, 2006
vietfob714's Avatar
heres a pic
ID:	68692   Click image for larger version
Old Nov 27, 2006
whats that big *** hole on the bottom for?
Old Nov 27, 2006
vietfob714's Avatar
thats the 4th sub... but i didnt screw it in yet
Old Nov 27, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Looks like some potential cancellation issues.
Old Nov 27, 2006
vietfob714's Avatar
Please explain ...
Old Nov 27, 2006
i wouldnt do that. close off the bottom and run 3 subs if you dont have room to put all 4 in a row. or make a seperate box for the 4th and put it somewhere else.
Old Nov 27, 2006
Because the subs aren't all in the same plane some of the sound waves can cancel out with each other likely resulting in deconstructive interference. When all drivers are in the same plane they will create waves at the same point and these waves will be in phase. The waves created by the lone driver will not be in phase with the waves created by the other three. The intermingling of these waves can cause bumps and dips where they shouldn't be thus altering the sound.
