K24 Frank begins.
Old Nov 21, 2006
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
K24 Frank begins.
i picked up a k24a4 accord longblock. No tranny. the frank begins.
BONE STOCK K24A4
Hytech Cams
Comp Stge 4 Clutch Kit
12LB Flywheel
pistons and rods installed
Old Nov 21, 2006
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
Frankenstein swap?
Old Nov 21, 2006
s0ltker's Avatar
- hella tite y0 -
s0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nice
k24 with a k20a2 head
byaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhh
Old Nov 21, 2006
d17acivic's Avatar
d17acivic is an unknown quantity at this point
i look forward to seeing more with this
Old Nov 21, 2006
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
are there special mounts for the K24 or can u just use the hasport ones? for example i have a A3 swap with hasport mounts if i wanted to go K24 can i use the same mounts. Im intrested in doing this also.
Old Nov 21, 2006
Voiceofid's Avatar
End Bringer
i believe the tranny mount is different, but hybrid is working on that
Old Nov 21, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Have fun, want to give us the details of what your planning to do?
Old Nov 21, 2006
HondaLuver's Avatar
Its a celebration bitches!
you have to use a k20 tranny. hasport makes a special mount for the k24. and with the k24a4, you will have valve clearance issues. you should have gotten a k24a1
Old Nov 21, 2006
scansel912's Avatar
Well he might have gotten his very cheap like I got mine (< $800) and would be planning to swap pistons down the line anyways.
Old Nov 21, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
nice!
Old Nov 21, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
so k24a1 is the motor to get? with any frank setup get you run the si 5 speed tranny?
Old Nov 21, 2006
scansel912's Avatar
Whats the status of your build btw?
Old Nov 21, 2006
HondaLuver's Avatar
you can run any k20 tranny. 6 or 5 speed. the problem with the k24 tranny's are that the case is too big
Old Nov 21, 2006
HondaLuver's Avatar
my custom pistons and rods are done. they are at the build shop with my sleeved block. i still need my head to get done. i just got a tsx tranny. i am putting those in a type S tranny case with a 4.4 finial= longer gears.
if you look at my profile. i have the finished setup of the block there.
Old Nov 21, 2006
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
So when you drop a k24 in what subframe do you use?
Old Nov 21, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
FYI, i hope your not planning ont TRYING To attempt to put a K20 head on the K24a4 every where that i have read on different forums said thats the only engine you cant put a k20 head on.
Old Nov 21, 2006
burke420's Avatar
The World Is Yours!
well... i had/still have the chanc to get a K20a2 block, engine with tranny for like $500. only problem, needs intake mani... i held of for a few months now, i want it but i dont want to go through the hassle of getting all the parts, but i think itll be cheaper to get a full clip, since i got an Auto and all... so what your 2 cents??? should i get it and get the parts and Frank it, or get it, and turbo it?!
Old Nov 21, 2006
burke420's Avatar
The World Is Yours!
also i get teh axles, injectors, harness, and brakes, for the 5-lugger if i want.. but i like my rota and dont wanna lose them
Old Nov 21, 2006
scansel912's Avatar
It fits, you just need to have aftermarket or TSX, or CRV pistons. The accord pistons will hit the valves of the k20 head.
Old Nov 21, 2006
yeah i knew about that, but wasnt there also something to do with the oil something lol *cant think of the name.* like a passage not being there or sometihng.
Old Nov 21, 2006
scansel912's Avatar
Yeah, you'll have to do away with the oil cooler passage in the block unless you have a machine shop do it for you.
Old Nov 21, 2006
RAZRBLD's Avatar
TEIN MAN
Oh hell no bro I did alot of research on the k24's all of them and what works and what wont. I pulled the pistons and rods crank stripped her bare.... im going 13.5:1 Custom JE Pistons with some IB K24 I Rods. Then a Type S head with IPS k2 cams, and a quaife LSD 6-speed Tranny...
Old Nov 21, 2006
RAZRBLD's Avatar
TEIN MAN
hey honda luver will the EP3 axles fit the frank swaps?
Old Nov 21, 2006
RAZRBLD's Avatar
TEIN MAN
yeah people do use the type S oil pan and system.. I just picked up an oil pan and baffle from a type s.
Old Nov 22, 2006
If you get stuck look here:
http://www.k20a.org/forum/showthread...4a4%2Fk20+head
Old Nov 22, 2006
RAZRBLD's Avatar
TEIN MAN
yeah bro I have been reading thatand asking lots of questions.
Old Nov 22, 2006
atl01's Avatar
there is also some helpful info in this thread as well. http://forums.clubrsx.com/showthread.php?t=429571
Old Nov 22, 2006
HondaLuver's Avatar
Good job on all that research man! the only way i learned was lots of readings and thread searching. and alot of trial and error. usually the only reason i will help people now is if they can prove that they atleast tried to search for their answer and got nothing. hit me up if you need any help.
the ep3 axles willl work perfectly. are you going to run this on pump gas? or is this a track car?
Old Nov 22, 2006
RAZRBLD's Avatar
TEIN MAN
Pump gas 91 octane V-POWER from shell... nikos from k20a.org was running a 13.5:1 compession k24 on 90 pump octane.
Old Nov 22, 2006
RAZRBLD's Avatar
TEIN MAN
Thanks for the help bro I will keep you updated on my build up.
