200 horsepower
Old Nov 4, 2006
axekid07's Avatar
axekid07 is an unknown quantity at this point
200 horsepower
Is there any way to get a civic to 200 whp w/o going turbo????
Old Nov 4, 2006
genexrocket's Avatar
swap and naaaawssss!!!
Old Nov 4, 2006
Civicman1988's Avatar
i am trying to hit that 200 horsepower with out turbo and right now i have all custom bottom end parts i think its possible it justs going to cost $$$$$
Old Nov 4, 2006
civic01vtec's Avatar
A civic yes, a 7thgen no.......unless you swap or juice. With juice, you better beef yup your engine/fuel system for the 200 mark.
Old Nov 4, 2006
if u want to know the parts i got aim me or PM me
Old Nov 4, 2006
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
^what hp are you at now? sounds like a cool project
Old Nov 5, 2006
rigth now i am pretty much stock i am just building another motor to put in. Just bought a few parts from my buddy supermex. Iam just saving and doing everythign right
Old Nov 5, 2006
axekid07 if u want to hit 200 horsepower u can just take ur time do ur research. I am working on decsion a few parts so if anyone has any ideas on parts to make for N/A post them
Old Nov 5, 2006
tfnaaf's Avatar
BLDNPSI Mod
is it possible ? YES, practical, NO. It would require lots of custom work including a complete reshaping of the cyl head(flow testing), higher compression pistons, big cam, custom intake, Throttle body, Fuel system..........Not to mention a lot of expirmenting with different cams, pistons, porting of the head. Then your talking about a car that wont be very friendly to drive around town
Old Nov 9, 2006
Your right not friendly but i am just taking my time and customizing everythign i can
Old Nov 9, 2006
SOAD's Avatar
SOAD is on a distinguished road
not worth it at all
Old Nov 9, 2006
WhiteCastle's Avatar
with all the money to make the lawn mower engine faster, you can buy a k20 and upgrade that well
Old Nov 11, 2006
andyman97's Avatar
Turbo Guru
Its possible. What did aem put down with the ems on a stock d17a2 with bolt ons? 12- something if I remember correctly. I think with a stage III cam, valvetrain upgrade, very high compression pistons and good rods, with a very good port and polish job, you could get pretty close with the right bolt ons if you had them custom made....maybe a custom itb setup would work as well.
People don't see gains on d17's with bolt ons because they don't tune the air/fuels and timing for optimal horsepower. You get a system that allows you to do everything like the aem does and you will see the difference with the bolt ons.
Old Nov 11, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
the whole point of sticking with the d17 is to show people up. not many know how to squeeze power out of a d17 but for those who do i give them mad props cuz those are one of a kind set ups. anyone can buy an rsx with bolt ons and kpro tune and hit 13s. not everyone could do that in a d17. keep modding your d17s guys!
Old Nov 11, 2006
Michalo187's Avatar
Abortion Survivor
I say d17+10000=150whp at most with god on your side
K20/k25 cost about 10000 with people doing it for you and your would get over 200whp
turbo with built engine cost about 10000 and get over 200whp
So N/a is not the way you would wanna go unless its with k-series just dont waste time and money
Old Nov 11, 2006
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
damn dude.. been a while, how are you
Old Nov 11, 2006
diskreet's Avatar
I think you could def. rebuild the engine, tune the hell out of it, and maybe a small spray, get to 200 to the wheels.
Its possible, but very costly.
Old Nov 11, 2006
I plan on going all motor do u think i should get a stage 3 camshaft or a stage 2 camshaft? Also i just got new pistones 76mm 12:1, bigger rods and a custom crankshaft, rings, bigger bearings and I am looking into purchasing customm sleeves. I got all that for 1600.00 All custom u cant purchase these from anyone. I want to get a custom made intake manifold but hveing a hard time fing a place to make one. If anyone knows where i can get sleeves for a 76mm piston let me know and i know its possible u just have to use ur brain and make custom parts
Old Nov 11, 2006
andyman97's Avatar
Turbo Guru
I'd go custom grind all the way. Do a little research and try finding some specs from all motor d16 setups. Contact crower and see what they'd want for a turbo cam to the specs you find.
And if you're using 76 mm pistons, no need for sleeves if you're keeping stock bore but I'd very seriously consider sleeves with an overbore and wider diameter pistons if you're serious about hitting 200.
Old Nov 11, 2006
what kind of overbore would u recommend? Should I use my stock cam if i have it custom grinded?
Old Nov 11, 2006
andyman97's Avatar
Turbo Guru
You can try it that way. I would think crower would start with a cam from scratch. As far as bore size, if it were me, I'd strip the bare block and send it to Dan Benson. Get on the phone with him and tell him what you're wanting. Tell him to go as big as he can to keep the reliability in the sleeves. Whatever he ends up doing, go with that size piston in maybe a 12.5 cr (my preference would be a cp piston.)
Just do some research. There is alot of info out there on the sohc honda sites. Check out sohchonda.com, those guys know their stuff although they are all about the cheapest way possible lol.
Old Nov 11, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Yeah I dunno is 12:1 is enough compression. I'd go at least 12.5:1 or even 13:1 which you CAN run safely on pump gas if you have a nice tune.
Also, have you considered ITB's?
Old Nov 11, 2006
andyman97's Avatar
Turbo Guru
^Yeah exactly, that's why I suggested itb's earlier. They're expensive but the flow benefits are well worth it, it'll definitely be something youl have to pioneer. Also, the higher compression, the better. I've never personally done an n/a build but I am familiar with the setups. It's primarily the ability to flow and obviously, the bigger the cylinder displacement and the smaller the combustion area, the more power you will make. I can tell you, the primary area of restriction you have to overcome is the head. Hell, the stock head won't let me make more than 260 whp. If you can hit 200 whp n/a, you can run a 12.
Old Nov 12, 2006
itb does that me intake throttle body? Does that Dan Benson have a phone number or a website to contact him at? I got 76mm pistons and i got a compression of 12:5:1
Old Nov 12, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Example of ITBs
Basically its having a small throttle body on each cylinder (4) instead of 1. You can tune each cylinder this way for maximum flow.
Old Nov 12, 2006
tfnaaf's Avatar
BLDNPSI Mod
ITB D17 has been done before. There used to be a guy here in the Northwest that did it shortly after the d17's came out in 01. I'll try to find some pictures of it if they are still available
Old Nov 12, 2006
I would appericate it
Old Nov 12, 2006
Originally Posted by XSRCivic
Example of ITBs
thats a good idea. Do u know where i can get one made for are cars?
Old Nov 12, 2006
andyman97's Avatar
Turbo Guru
His business goes through Earl Laskey. Those guys are really cool and very helpful.
http://www.laskeyracing.com/shop/sleeving.htm
Old Nov 12, 2006
Thanks man what do u think of that ITB or should i have a cutom one made like u did with a mustang throttle body on it? I am int he process of making an intake manifold with the mustang throttle body the only part i am having problems with is where the pipe meets the manifold i am having a hard time finding a shape that way. If u know of anyone that i can get that piping let me know
heres what i mean the part after the injectors all 4 cylinders that pipe that goes out into the big manifold
http://www.7thgencivic.com/forums/sh...d.php?t=282569
