M/T Fluid check
There are 2 plugs, an upper and a lower. They are located on the transmission, when you drain from the bottom seal it up, and then fill through the top until it starts to seep out. That is how i checked to see how full the trans fluid is full. If you just want to check the level then remove the top plug and check it with your finger. There is not a dip stick unfortunately.
Xuhme
21
Aug 7, 2023 03:40 PM
