Everybody run!!! I have a plan...
Old Sep 23, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
New shortblock from honda
9:1 pistons
Crower rods
ARP hardware
Fancy redone head with some cam I haven't come up with yet
One off IM that I haven't thought up yet
Little turbo, and a whole lotta boost instantly.
3 questions...
Has anyone figured out if there's interchangable oil pumps? Its kind of a well known fact that the Z6 pump was much better than the rest of the D16 pumps... anyone know if this one is better or worse (which I assume) and what if any interchangability there may be?
Second... sleeve or no sleeve. Once again going on the D16 assumption 15 lbs seems to be the limit. I'm intending to run 10-11. Do I anticipate shooting a rod through the block? no, but I suppose the stock sleeves could walk on me. Block guard is an absolute no. I don't want to obstruct water to the head.... I'm doing this so the car can go on the track and not blow up, as much water as possible needs to move as fast as it can.
Third... who's got a picture of how much block notching needs to be done for the rods?
The fun part... I'm doing it myself (machining, if necessary, excluded)... gotta buy some more tools.
Old Sep 23, 2006
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
sleeving the block is not a bad thing at all. At least you know it can hold on you if using aftermarket sleeves. I am not sure about changing the oil pump but if I can remember right it can't be done but do not quote me on it. Anyways sounds like you are on your way to a soild engine build
Old Sep 23, 2006
yea sleeve for sure just in case, no block guard.
Old Sep 23, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
Wow, man. I'm envious. Hope it goes well. Do you have a shop to work in, or are you doing this in your garage?
Old Sep 23, 2006
Civicman1988's Avatar
I plan on sleeving my block. Are you doing this to a D17?
Old Sep 23, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
This pic may help
And if you open the water intake of the Block Guard you will get better flow
I burned two head gaskets because of walking after I installed this no problems and is hot here in florida
Old Sep 23, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you could post the block instead of using a block guard. it works the same way just some people think of it as being ghetto. Serves the same purpose with less fluid restriction. search block posting.
Old Sep 23, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
sounds like fun..you plan on auto-xing it?
Old Sep 23, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
What about changing the springs inside the pump? If you researched what to change on the D17 pump im sure it can be done. I've heard of people doing that with k24 oil pumps and making it better.
Old Sep 23, 2006
tfnaaf's Avatar
BLDNPSI Mod
you thinking bigger on the turbo???
Garrett GT2871R
Old Sep 24, 2006
andyman97's Avatar
Turbo Guru
Sleeves aren't necessary bro. Everyone will tell you that you "should" just in case but if your tune is good and you watch your a/f''s, you'll be fine. I've been on 17ish psi for about 3k miles now and no problems at all, compression is just fine and my turbo isn't a small one.
Hectors pic should show you enough what the notching involves. After you notch, just bolt the big end onto the crank and measure your clearances. I'd say make sure you have no less than 20 thousandths, pick up a feeler gauge so you can check it.
If you're doing the rebuild yourself, feel free to hit me up if you have any questions. Its relatively easy but its also important to know what specs need to be different from oem, ie: ring gap, etc, etc.
Old Sep 24, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
The housing for the D16 oil pump bolts right up to our blocks but the drive is different. If you find a free junk D16z6 oil pump and rip it aparts maybe you can see if the parts are interchangeable. If they are buy a new one of each and make your own. I honest dont think you will have any problem at all running the stock D17 oil pump. Honda makes good OEM ****, Id run as much of it as possible with exception to the rods, pistions, and rings of course.
Old Sep 24, 2006
burke420's Avatar
The World Is Yours!
nice block supermex
Old Sep 24, 2006
skipbarber's Avatar
this is going to get interesting...
Old Sep 24, 2006
Jap-Euro Fusion
Walk in closet. This may also be a first, but I'm going to prep it so I can keep everything clean and the dust/grit to a minimum in the motor and my apartment.
Garrett GT2871R
For now, no, the 2854 should be fine for now, If I get nuts, I may upgrade to the disco potato w/ a T3 hot side conversion... but not now. The turbo I have should be more than enough to keep the party going. Also, with the HKS manifold, I can't get a larger compressor in there anyways, the core support is already sectioned and bent to keep the compressor from hitting it.
You know it
Last edited by Boilermaker1; Sep 24, 2006 at 07:03 PM. Reason: Automerged Doublepost
Old Sep 24, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
dont remember where exactly i saw it, but i saw a d17 with some sort of dry sump oil pump on it ages ago. it kept all the oil in the lines and left the pan empty or something. guy said it was neccesary for 10k+ revs. he was building the worlds fastest d17 powered em2. maybe look into that and see if something inspires you.
Old Sep 24, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
^ i think he is a member. If its the same one your thinking of, A destroked B16
Old Sep 24, 2006
ill dig around in some magazines and tv shows i have on my pc and see if i can find it somewhere. it was a boosted d17 though. i saw it on the salt flats or something. he made a 200+ mph run with an em2. dont know if it would be worth it or not. if i remember correctly it took a lot of modifying and im pretty sure its probably a one off piece.
Old Sep 24, 2006
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
yea your talking about the b16... its not a d17... the vic is blue right?
Old Sep 24, 2006
^agreed...there was a feature in superstreet and another in honda tuning i think..em2 chassis, but a destroked and boosted b16 underhood. came in at just under 1.5 liters. I think it was sponsored by AEM. i remember the aluminum-dish hubcaps...reminded me of the old moon eyes wheels everybody used to rock on old school bombs
Old Sep 25, 2006
ok maybe it was a b16. must be another article on the most powerful d17 then. got any info on the oil system used on the b16? maybe something there could be useful on boilers project.
as soon as i posted i flipped open to the article. november 2005 honda tuning page 78. its a boosted b16 blue em2. its a barnes systems three stage dry sump pump z10 kit. up to 125 psi. hope some of that might be useful.
Last edited by _unclejuice; Sep 25, 2006 at 05:12 PM. Reason: Automerged Doublepost
Old Sep 25, 2006
Jap-Euro Fusion
I'm not drysumping the oil system. Thats a pain in the ***.
Old Sep 25, 2006
sure its a pain in the *** but could be well worth it for 10k+ revs
Old Sep 25, 2006
tfnaaf's Avatar
BLDNPSI Mod
ABSOLUTELY no reason to rev that high on a street car, or even a street/track car, but back on topic , keep us posted..... I too have had thoughts of bigger numbers.... was thinking swap . But with the good foundation i currently have on the turbo system it may be a better idea to swap out some parts and build some more boost/flow
Old Sep 25, 2006
Jap-Euro Fusion
The motor would never support it, the stroke is too long, the head wouldn't flow and there's no valvetrain that could handle that.
Back to the original fun... Majestic Honda pissed me off today, they won't ship me a block... so I gotta drive to Rhode Island to get it, or find a place closer that has it for a similar price.
Old Sep 25, 2006
maybe somewhere in maryland? or VA? i'm sure there's somewhere in VA....
Old Sep 25, 2006
They wont ship you a D17 block?
Old Sep 26, 2006
dezod's Avatar
7thgen Power Maker
Good news is.....we shipped all of our stuff to you Boiler.
Old Sep 26, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I dont know but i think you would need something like this.. If they only made it for a D17 though..
Old Sep 26, 2006
Jap-Euro Fusion
Well I think we all already knew Dezod>>> Honda, but that stuff is to keep this one alive long enough to get the other one finished. I'm taking my sweet old time though... and giving you time to finish the head and IM... so hurry up!
