Question regarding Oil/Oil filters
Old Sep 10, 2006
pyroz's Avatar
pyroz is an unknown quantity at this point
so..ive decided that i'll change my own oil and filter. I first have a few questions, i have an 01 civic lx, and the oil cap said 5w-20, is it ok to use 5w-30 or no? and what kind of filter is best for a civ? wheres the cheapest place to get mobil 1 syn? thanks alot guys!
Old Sep 10, 2006
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
i use fram oil filters
part number ph7317 ...
the oil is up to you there.. i use quaker state high mileage synthetic..
regarding the 5w30 ... use 5w20 because your car is calibrated for 5w20 and if you a slightly thicker oil it can cause damage... ive never used anything outside whats recommended..
Old Sep 10, 2006
use 5w20. use oem filter, or better like K&N. i would not use fram
Old Sep 10, 2006
pyroz's Avatar
where can i get mobil 1 syn 5w-20 cheap? costco and bjs dont have it around where i am, maybe walmart?
Old Sep 10, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
I also use Fram PH7317, with Penziol 5W-20. My dad is a mechanic, and he said to use it, so I trust him lol. As far as where to get Mobile, I have no idea becuase I dont buy it. My advice is just buy it in bulk when its on sale. Like I live near O'Reily's Autoparts and when its on sale I buy a few gallons then I am set for a while
Walmart should have it. They have an asston of oil.
Old Sep 10, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Mobil 1 is cheapest at walmart i believe. But i'd recommend going with pennzoil platinum since its $2 cheaper, and a great oil.
5w-30 would work fine, but there is no reason to use it instead of 5w-20.
Good oil filters which are easy to find:
Purolator premium plus $3ish
Purolator pureone $5ish
Napa gold $6ish
Buying an expensive oil filter isn't necessary and is just a waste of money. I buy Wix oil filters which are the exact same as napa gold's.
Old Sep 11, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
If you want some really good stuff check out Amsoil and their filters, expensive but good.
Old Sep 11, 2006
streetglower's Avatar
you would be fine with 5w-30. I have been using it for a long time now and at 123K miles my car runs like a dream. no oil consumption of any type.
Old Sep 11, 2006
Jrfish007's Avatar
Napa gold $6ish
What he said. I'll add that the Pulator premium filter is MUCH better than the Fram filter. Fram filters (the base ones anyway) are rather scary when you look inside of them. And I agree with him the your oil is only as good as your filter, what the point of putting expensive oil in and then cheaping out on the filter? It's like having 10 armed guard at the front of a bank, and leaving the bank door wide open with no one there, why bother with the guards in the front?
Old Sep 19, 2006
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Fram will not hurt your engine but for the same price you can get a much better filter like a Wix or Pure One. As far as oil, 5w30 will work fine, it will NOT cause damage to your engine. if you want more info on oil/filter visit www.bobistheoilguy.com
Old Sep 21, 2006
MarkieMark's Avatar
MarkieMark will become famous soon enough
true that.
i use m1 5w30 w/ fram oil filter.
no problems here.
Old Sep 21, 2006
mellow_civic's Avatar
mellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trusted
honda filter and fram = same ****
and no 5w30 CANNOT damage ur engine
Old Sep 21, 2006
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
yep OEM filter does the job nicely and I go with Mobil synth 5w-20
Old Sep 21, 2006
dalaw's Avatar
Bone Stock!
you can get mobil 1 at pepboys or kragen or autozone for 5-6 bucks a quart
Old Sep 22, 2006
Jrfish007's Avatar
Sorry fram filter does not equal the same.
That like saying a corvette is crap because it's a GM. Not all GM are the same.
Old Sep 22, 2006
haha have you looked at a fram side by side with oem? obviously not.
Old Sep 22, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
Royal Purple 5w-20 and HAMPA Filter... using the hampa filter u get a small increase (5%) in oil pressure atleast thats what the S2K guys say... at 9 bucks a filter better do that
Old Sep 22, 2006
thecheat's Avatar
thecheat is an unknown quantity at this point
oem filter (cut one open sometime, it not the same as a fram) and a good full synth oil 5w-20. One MPM oil becomes available in the US thats what I'll be using for now mobil 1
Old Sep 22, 2006
es2001civic's Avatar
es2001civic is an unknown quantity at this point
I use Mobil 1 full synth oil 5w-20.
Old Sep 22, 2006
ctx66's Avatar
some honda filters are completely different than frams, some are the exact same. orange adbv? so what, doesn't mean its a different material. could be nitrile or silicone, i forget which off the top of my head since i dont use honda filters.
Old Sep 23, 2006
Jrfish007's Avatar
Even the Honeywell (Fram) filter has twice the filter media as your standard orange Fram filter, even if it is the same material, the extra filter media helps out.
Old Sep 24, 2006
ctx66's Avatar
link?
Old Sep 25, 2006
Jrfish007's Avatar
well.... I don't have the link that put the two filters up agianst eachother directly. But do have some pics
Here is the S2000 Honda OEM filter and the cheap Orange Fram filter cut away. Yes I know the S2000 filter is not the same as the Honeywell OEM filter for the civic, but just look at the Fram. For the purpose of the Fram filter, they are constructed about the same rather if it's for the civic or the s2k.
Now here is the OEM Honeywell filter for the civic.
Anyway, you can see the OEM Honeywell (Fram) filter definately has more filter media, I'm not exactly sure how much better this makes the filtering, but the comparison that I can not find claimed it made a pretty good filter with the added media.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
mistermenphis22
Jul 13, 2015 04:43 PM
BootyDo
Jul 7, 2015 06:06 AM
superstanko
Apr 28, 2015 04:38 AM
viper775
Dec 9, 2001 10:52 PM
