Rough checklist for custom turbo
Old Mar 13, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
I was bored one day and got to thinking about the whole custom turbo idea and forgive me if im wrong but this is what you would need to do the job.
1. Get Some type of turbo
2. Get a header made up to fit that turbo
3. Get fuel pump and regulator from an acura rsx
4. Get some sort of engine management system (EX: AEM engine management system)
Again, this is what i came up with. If theres something im missing, post it.
later
Old Mar 13, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
How bout an intercooler, intercooler piping, downpipe, blow off valve, and waste gate?
The guys at South Florida Performance can hook u up with a custom turbo manifold.
You may also want to upgrade to at least 2" piping so the turbo will spool up a bit quicker.
Of course, the first thing you'd have to do is make room for the turbo.[IMG]i/expressions/laugh2.gif[/IMG]
Oh yeah, you would probably want a boost gauge and A/F ratio gauge.
Old Mar 13, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
You might also need a TURBO TIMER!!! And you will need to open up that motor and change the compression ratio as well as perhaps port and polish a few things. Slapping on a turbo is fun, but not if you don't prepare that little motor for what's coming. Depending on how strong the turbo is you may even need to get reinforced or stronger motormounts. Did you forget you will be needing new clutch too (if your car is stick that is). You can even go with 2.25" piping for the turbo. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Just a few more suggestions.
Old Mar 13, 2002
Bridge's Avatar
Bridge is an unknown quantity at this point
a/f gauge as well as boost gauge wouldn't hurt
Old Mar 13, 2002
avenger's Avatar
avenger is an unknown quantity at this point
you wont need to drop the compression if you keep the boost down
Old Mar 13, 2002
AEMcivic's Avatar
Yeah, if you want to go above 4 or 5 lbs of boost, you better rebuild your bottom end.
Old Mar 13, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
Not too mention the various fittings and such. Aslo, have you even considered where you will tap into the block for an oil feed line. Im looking over it this weekend, but just wondering if anyone is a step ahead of me.
Old May 21, 2002
ILLWILL's Avatar
ILLWILL is an unknown quantity at this point
if hey doesnt use more than 8 pounds of boost he doesnt need any engine mods all he needs is a head gasget
ones he goes ova that limit hes gonna need engine mods but i daubt hed be able to go higher than that anyway cause getting our engiens to pewk more gas is gonna take money
[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 21, 2002
ILLWILL's Avatar
and as far as taping for oil there should be a plug some were that should work i herd a friend talking bou it
Old May 22, 2002
silver02civic's Avatar
silver02civic is an unknown quantity at this point
ok every one forgot one thing............................money and lots of it
Old May 22, 2002
SiBorland's Avatar
SiBorland is an unknown quantity at this point
dont forget a cast iron manifold, ignition, plugs with a colder spark, plus wires, intake, high flow cat, boost controller....lots of loot for that, but more power to ya if you can afford it.
Old May 22, 2002
RallyEX's Avatar
RallyEX is an unknown quantity at this point
Here's what I was going to do:
T25 or T3 Garrett Ball-Bearing Turbocharger
Trust Intercooler, piping, etc.
Greddy Dual Sequential BlowOff Valve
Colder spark plugs
Custom Exhaust manifold
Fuel Pressure, Boost, A/F Ratio Guages (knock sensor too)
O2 Sensor Simulator
Custom downpipe, exhaust w/ hi-flow cat & APEX'i Dunk or N1 muffler
Turbo Timer, Oil Pressure guage tapped just before the turbo
All fittings, etc.
Our fuel system can handle a 50 shot of nitrous and compensate, so it will compensate 5-7psi of boost.
As for tapping in to the Oil line for the turbo, there's a threaded spot on the block where a line taps in, can't remember where, but a T-Fitting and the proper hoses/fittings should do the job.
Old May 23, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
you can tap into the oil from where the oil pressure sending unit is, but make sure the tap has a spot to hole the sending unit or your oil light will always be on.
HondaGuy7
Feb 22, 2016 01:00 PM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
