Sponsored by:
Sponsored by: CARiD
anyone using a front camber kit
Old Mar 12, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
if so what brand and which one cause i'm lookin at ingalls and they have a 1 degree and 2 degree. Just wondering which one you guys have used and how low you are. thanx
Old Mar 12, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
I have a 2 inch drop on my NEX coilovers with Eibach cambers in the front
Old Mar 13, 2002
sentinel's Avatar
sentinel is an unknown quantity at this point
NoBottleJustThrottle: i just wanna give you a warning... check your NEX coilovers every noe and then... take a good look at your steering arm and watch for cracks in the weld beeds. my friends broke on him... luckily we weren't canyon racing at the time... he'd be dead. hit me back in PM or post here... if you have any feed back or questions.
Old Mar 13, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
I am using the Ingalls, but the Eibachs are the same.
Basically the kits are bolts that replace your stock mounting bolts on the strut to the spindle. It has a cam on it and rotating it pushes the spindle out or in. The one degree is only one pair (top bolts). The two degree is two pair (top and bottom). They are easy to install and are pretty cheap compared to the rear.
The alignment guy will tell you how far you are out, and then suggest how many bolts. Mine were 25 a pair, with 35 to install them, plus 60 for a full alignment.
Old Mar 13, 2002
Ben's Avatar
Ben
ok well i just wanted to get it all done at once cause the guy doing my drop is also doing the alignment so i wanted to have the set there. somebody on here said i would need the 2 degree for a neuspeed sport drop of 1.5. so i guess i'll get those and if they don't work exchange them for the others or just buy both and return the one i don't use.
Old Mar 14, 2002
Hey thanks for the warning...ive actually heard about that from one of my friends. I just checked mine out, and no problems what so ever. You can believe that i drive the ***** off of them too. But thanks for the concern
Old Mar 14, 2002
GSTARR's Avatar
GSTARR is an unknown quantity at this point
Eibachs all the way around for me....with the alignment it looks and rides great. 1.8 inch drop with sportlines
Old Mar 14, 2002
sentinel's Avatar
i've got pix somewhere here of his being broken... ill find them sooner or later
Old Mar 14, 2002
01Ex's Avatar
01Ex is an unknown quantity at this point
I had the NEX too and there on call back. If you i am BSing then call Golden and ask them
Makeice3498
Jul 2, 2015 11:13 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
JeffSpeed21
Nov 4, 2001 10:32 PM
ImmortalEX
Oct 31, 2001 10:00 PM
