quick quick ground wire question for amp
Old Aug 31, 2006
jonku's Avatar
jonku is an unknown quantity at this point
where is a good place to put the ground wire for a amp? I looked everywhere and i cant find any good spots. I searched the forum but i couldnt find a exact answer... eveyrone just says find a bolt and your done. Just need to know where this so called bolt is... thanks!!!!
Old Aug 31, 2006
SDhondarider's Avatar
SDhondarider will become famous soon enoughSDhondarider will become famous soon enough
If you mounted your amp in the trunk, pull back all the interior and plastic to find the rear strut (check the Suspension Forum to find out how to access it). Take the nut off only one of the three bolts, and place the ground wire on it, and retighten the nut back on.
Old Sep 1, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
nah, you don't need to do that. Just find any spot that's metal in your trunk. Sand the area around your grouding point, and it should work fine. My grounding point is on the hump just behind the rear seats. I can take a pic tommorrow if you want.
The reason why you can't ground your amp. There's paint on the metal, so it won't ground like that. So sanding the paint off is the most important part.
Old Sep 1, 2006
jamis33's Avatar
You Stay Classy, San Diego
the easiest and best place to ground your amp is if you pull back the carpet around the side of the trunk and there are those little black screw/clip things that just snap in the holes pick the one near the bottom on the right hand side. Pop out the little plastic screw/clip thing, pull back the carpet and sand off the paint to bare metal. Then find a nice washer and put that on the plastic thing then put your wire on it and put the plastic screw/clip thing back in. That works really good for me (the washer isnt necessary i just use it because then it guarantees that there is lots of metal to metal contact)
Old Sep 5, 2006
electric130's Avatar
that's where i put mine. i drilled and tapped a hole and sanded around it. works great.
dinsum
May 28, 2015 09:30 PM
jackoncruzpr
May 24, 2015 12:24 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
blackbullet
Dec 1, 2001 03:44 PM
MooCoW
Nov 9, 2001 05:22 PM
