Painting valve cover
I'm going to use regular spray paint not high heat. and just put a clear coat over it. has anyone had a problem with regular? i know that someone had a problem with high heat chipping and not sticking to the plastic. i'm just gonna use regular spray paint
::cough:: spark plug cover ::cough::
edit : you should lightly sand the plastic with a fine fine sandpaper to prep the surface, there are a few threads on this but im way too lazy to search [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
I used engine paint that stands up to 500 degrees. Painting on the valve cover it doesn't chip but on the battery tie down, it does. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
just remember to sand it first.. prime it second then .. sand it lightly again. then paint..
and about the paint u use.. i used the same paint called "plastic" not sure of the spelling but the paint in the DIY used for the interior of the car
had mines for half a year no problem
Civic15
18
Sep 19, 2017 07:48 PM
BootyDo
Jul 7, 2015 06:06 AM
