Help!! idle rough!!
Old Aug 23, 2006
lumpy007's Avatar
lumpy007 is an unknown quantity at this point
Help!! idle rough!!
my car died today and found out it was the battery so i put in a new one but now it idles kinda rough almost like its gonna stall out !
Old Aug 24, 2006
streetglower's Avatar
need to do the idle relearn.
Old Aug 24, 2006
lumpy007's Avatar
ok what?? and how??
Old Aug 24, 2006
PCM / ECU Reset and Idle Learn
1. start the car and drive it until the engine is at full operating temperature.
2. Park the car, turn off the engine, and pop the hood. Locate the fuse box and lift up the top cover. Using the supplied fuse puller, remove the FI ECU fuse for at least 10 seconds.
3. Replace the fuse and close the box. Make sure that all electronics and accessories are in the off position. Start the car and let it idle for 10 minutes with the hood closed. Do not press on the gas or turn on any accessories during this time.
4. After 10 minutes, turn off the car. The idle speed should now be set. Start the car and go drive like you normally would so the PCM can relearn the fuel maps.
Old Aug 24, 2006
lumpy007's Avatar
thx alot i will try it in the morning!!
Old Jun 16, 2010
kenito's Avatar
kenito is an unknown quantity at this point
Re: Help!! idle rough!!
any ideas to free stuck idle screw on 94 Civic DX? The car idles a liitle rough especially with A/C on.
SimpleUser
Apr 24, 2021 02:54 AM
lyanreindecker
Aug 20, 2015 09:15 PM
GritzNGravy
Aug 19, 2015 03:03 AM
alaga
25
Aug 13, 2015 04:42 PM
1khilari
Jul 9, 2015 08:12 PM
