Steering Gear? Alignment?
Old Aug 22, 2006
EM2_FRESH's Avatar
EM2_FRESH is an unknown quantity at this point
so today as i was bringing a friend home i was turning left into his subdivision which was on the opposite side of a median (it was a boulevard type street) and instead of slowing down completely i decided to beat the on coming traffic,(STUPID STUPID STUPID) and i did.. but as i got onto the street i was making a left on, i hit the outside curb. Rim-checked by GTR-4's but no biggy.. But soon i realized that my steering wheel was totally whack.. it needs be almost 45 degrees to the left to keep it centered.. so i went over to a NTB for an alignment.. and they said that they couldnt give me an alignment b/c steering gear is too far to the right.. and that i wouldnt be able to turn left if they did?.. i didnt understand but is this fixable? How?
pics later on..
Old Aug 22, 2006
Ti71's Avatar
Ti71 is an unknown quantity at this point
Check your tie rod, maybe it got bent
Old Aug 22, 2006
EM2_FRESH's Avatar
hmm yea well i looked but im not quite sure how to tell whether its bent or not.. and if so how much would it be to replace..
Old Aug 22, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
any one have an "exploded" diagram for our stering system?
Old Aug 22, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
a tape measure and some know-how will tell you if its bent.
Old Aug 22, 2006
mr_fobster's Avatar
if you did **** up your rack and pinion thats gonna be one expensive and time consuming repair.
how fast wee you going btw through the turn into the curb? cuz i i hydroplaned into the curb once before but all i broke was the lca and also my rack and pinon were coo and my tie rods, and i was going about 25mph. my steering wheels wasnt centered after that hit too. but after i did a wintoe adjustment on my car on the alignment rack it was all good.
all i have to say now is just jack up the car onto jack stands and just do a quick visual check of all of your front suspension components
Old Aug 22, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
well, i hit a curb before by avoiding a stupid driver that almost hit me head on, well i had a tie rod problem but i got it fix for 100usd with labor, knew someone on just tires but his gone now. well if you wanna check your tie rod, simply jack your car up and you can see the whether its bend or need replacement.
Old Aug 22, 2006
EM2_FRESH's Avatar
30 - 40 mph and i guess my falkens didnt hold out.. even though their nearly new. but yea I'm hoping its just the tie rod.. the car responds fine it just my alignment is shot.. and the distance from my front right tire to the body of the car (closest to the door) -- is about half its original distance.. and when the steerting wheel is straight the right tire isn't completed straight like the left one.. its slightly turning right.
i'm taking it to the shop 2m to get some estimates and such i take pics of the damages then.. hopefully someone can advise me..
Old Aug 22, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Probably bent your lower controll arm
Old Aug 23, 2006
mr_fobster's Avatar
it still could be a bent or even a cracked lca.....my was like that too after i hit the curb, and plus i drove it home and the steering wheel was vibrating like a *****!
Old Aug 28, 2006
EM2_FRESH's Avatar
alright so it turned out that i had bent my lower control arm and a strut. So they've been replaced and the car runs fine.. but now. My car sqeaks.. each time i turn the steering wheel left or right.. it looks/sounds to be coming from the rack & pinion and from my guess.. it looks as tho it may be rubbing against my frame..? is there like some sort of mounts or hooks that keep it from touching the frame? it seems as though when i turn left and the rack comes out towards the front right tire(damaged one) it bumps the frame!?! take it to the shop today after school.. all help accepted
Old Aug 28, 2006
how ever did i know lol. that sucks. just get it fixed.
hondadriver95
Jul 13, 2015 09:43 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
robbie374
Jul 7, 2015 02:56 AM
