WHo has replace crank bearing yet?
Im going to have to replace the crankbearings do to low oil pressure condition. I have changed the oil every 3000 with syntec and done every maintance for this car and now they saythe crank bearings are shot. Just woundering if anyone else has already had to replace there bearings yet. Ohh and by the way my honda is a 01 with 40,000 miles on it. Pretty sad if you ask me.
how do you know they went bad? what r the signs? this is a pretty rare thing i believe. i have only heard of this happening once and that was with a supercharged TC. shouldnt your oil light of come on if the pressure is low?
swapped the oil pump, oil strainer, gone through 4 different kinds of oils. Check the oil pressure with 2 gauges and still at idle i have 2 to 4 psi. While driving its fine oil pressure just at idle it sucks. Friend owns a machine shop and even he said that a tale tale sign the bearings are shot. 4 of my honda friends that have been techs for 30 plus years all say its the crank bearings and that its becomming an issue with the 2001 civic.
so wait if tha D17 is goin bad at 30,000 to about 60,000 miles, what would b tha point in replacing it wit another used D17 wouldnt it b smarter to just do a K series swap? im just wondering cuz quit frankly reading this is worring me because i have a 05 with around 40,000 on it, and i'll b tha first to admit i drive tha **** outta mine on a daily basis.
this is a rare problem, and he said it was due to low oil pressure. our engines are pretty good, its the tranny and other stuff that breaks first.
my engine was treated like a baby. OIl change with syntec 5w20 oil every 3000 miles. Yes I still did it at 3000 . And I still had problems with it. Ohh well , its at the machine shop getting fixed.
Jeff
Jeff
yes sir. Mine was 800 bucks to get the crank turned , new piston rings and new bearings on the bottom end.
I didnt trust any of the jap d17a's i went and saw. They were just nasty for only having 40,000 miles on them.
"I didnt trust any of the jap d17a's i went and saw. They were just nasty for only having 40,000 miles on them."
just because a engine is dirty doesnt mean it is bad. i hope u never have this problem again! those things are such a pain in the ***!
Originally Posted by drunkenmagnum
that sux fat *****. car trouble always blows. just replace the d17 with a new one, might be cheaper.
dosmastr
May 5, 2015 12:19 PM
thesushiboy
Apr 12, 2015 02:54 AM
15, 95, bearing, bearings, changing, civic, crank, crankcase, crankshaft, engine, honda, instructions, replace, replacement, replacing
