Yikes! CEL Ecu reset and radio problem! HelP!
Old Jul 29, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
Unhappy Yikes! CEL Ecu reset and radio problem! HelP!
i hope someone can help me, well i just installed my new header yesterday and i took off the battery and the ECU fuse to get rid of that CEL (check engine light), then everything went well until i drove to the freeway.... it turned on agian. and yea, i just realize that my radio is asking a code so i can turn it on... do you guys know the code? and how do i get rid of that Engine light?
installed obx header and hooked up the sensors back on (two of em)
i have civic lx 04-05.
Old Jul 29, 2006
streetglower's Avatar
since you have an LX model, your cat converter is part of the stock exhaust manifold so your new or aftermarket header doesnt contain that. so even if you re-installed the o2 sensors, the second o2 sensor that monitors the cat detects a fault, that is why the check engine light is on. The second one monitors the cat converter efficeny, so if the cat isnt there, your going to get a CEL. There is a part you can use, I forgot the name of it, someone will mention it, its on the tip of my tounge, but...... I think it is the MIL eliminator.
With the radio code, know one will know it except the dealer. each honda radio has a specific code. Check your glove box for the radio code. its on a card. otherwise go to the dealer and they will look it up for you.
Old Aug 1, 2006
nice.. thanks streetglower, it is actually the MIL eliminator and i bought one already.. hopefully works!!
and the code for radio.. yep your right its on our glove box where are manual is and there is a card attach to it... shoot that was easy! lolz
thanks much`
oh btw, for 04-05 lx, if i bought an sway bar rsx, do i simply bolt that in or i have to do some mod or buy somehting else?
Old Aug 22, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
You should of got the EX!!! But looks nice anyway!!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
McD
Apr 22, 2015 05:28 PM
dooner24
Apr 14, 2015 07:51 PM
AnotherDopeStyle
Nov 1, 2001 01:58 PM
