CD-IB100ii Pioneer ipod adapter
Old Jul 16, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
I have currently have my pioneer ipod adapter being mailed to me right now. It should arrive sometime later this week.
I have an installation quick about the adapter. It has 2 wires, one yellow (which I assume is battery), and the other black wire (which should be ground).
I just wanted to know if its ok to hook up wire to battery wire connected to my wiring harness on my deck. I should be ok with doing that??? right?? or do I need to find another wire to power the ipod adapter??
Same question for the ground wire. Can I just use the same ground that's on my wiring harness, or should I find a seperate ground for the ipod adapter, and a seperate ground for the deck. I know its probably better to find a seperate grounding location, but I should be ok with the same grounding wire?? yes??
This probably useless post for me, but I just want to make sure I'll be ok.
TIA, Phu.
Old Jul 17, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
yes the yellow is power (constant 12volt+) and the black is ground. that I-Pod unit only has a 2 amp fuse, meaning it doesn't draw too much power, so , i say you should be fine, cause i'd say your headunit draws between 4-7 amps, and your headunit fuse is good for 10 amps.
Old Jul 17, 2006
phuviano's Avatar
thanks, just got my ipod adapter today.
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
Jrosa
Sep 14, 2015 08:24 PM
