where to buy injector o-rings
where is the best place to get injector o-rings for rsx injectors other than honda. the idiots at autozone are lost. i might try NAPA but i wanted to see if there was a better place.
cool thanks, bu thow do i determin size without actually going through all the trouble of takeing them out first? does anyone know the size i need?
i know one of them is bad because it was damaged when i put them in.
I'm thinking its a spec to the injector and the hole in the injector plate/fuel rail (depending on which end) If you have another car, take the whole injector with you to Autozoo, and get it sized.
use this site
www.acuraautomotiveparts.org
just like hondaautomotiveparts.com, find the injectors for the car and it will list the size.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
sorry im gonna thread jack but its the same category.
i need to replace the o-rings on the d17 injectors and was wondering wat size they would b if i were to go to advance auto or any local auto shops? they have two different size categories: metric and standard. ive checked majestic honda to see wat size they were but they just give me 7.85X3.53. can anyone help me with the exact size in metric or standard.
example: ? x ? x ? or ? x ? thx
well did u also factor in the time to get to the dealership? it took them freaking 5-6 days to get my damn order of gasket, brake booster line, and fuel line when they told me it was gonna b here in 2-3 days. thats y i dont go there no more damn stealerships
yes, i did. that just varies depending on where you live. i guess im just lucky that i live so close to one of hondas warehouses. if i order by 5pm, i can get most parts next day. unless its some really rare part that they have to get from ohio, then its a 2-3 days.
although, i think it also varies depending on which dealer you go to. the branch warehouse im referring to is in connnecticut. my local dealer gets parts deliveries every day, and its in Mass. However when i lived in ct, and went to a honda dealer thats even closer to the warehouse, they told me 2-3 days........and it wasnt some strange part that was coming from ohio.
i had a leaky injector o ring on my integra and the dealer wanted $11.00 a piece for them. so i called a place called rocket seals and they had them for $.15 a piece. you have to be carefu because you need top make sure that they can handle fuel with out swelling or deteriorating(sp). call these guys but you will need to know the ecaxt size you need before you order http://www.rocketseals.com/
