Misfire with cam and how do i clean pluggs?
Old Jun 29, 2006
drunkenmagnum's Avatar
ok i know there are like a thousand guys out there with misfire prblems and everyone seems to be different including mine. i read the other post about the misfires(the ones i found) but non seem to be specific to my problem.
back when i turboed my car it misfired but i solved the problem with a o2 simulator and new pluggs. well now that i have the comp cam in the thing misfires all the time! what could it be? gasket,pluggs,other. i have checked the coil packs and am about to pull the pluggs. i am using BKR7E (if i remeber right). if it is the pluggs how do i need to clean them or should i just replace. obd2 says misfires1,2,3,4 and random misfire. uggghhh
the car has been retuned and still does it.
Old Jun 29, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Same problem!!!
I misfire on all 4 cylinders too.
Never fixed the problem. I can’t diagnose it.
I’m n/a though witha stock cam. It misfires when I start her up, and when I let off the throttle.
I through I think a P0301-4 code...
Old Jun 29, 2006
this may seem odd but i think it has to do with the IAT sensor. anyone agree or have any idea?
Old Jun 30, 2006
02BLKCIVIC's Avatar
What leads you to think that?
my .2 is
I think I have a bad cat...
but that's just my new theory.
Old Jun 30, 2006
take out the sensor (leave it connected to the harness) and move it outside the engine bay. see if it goes away. if you have turbo, the only plugs you should be using are copper (ngk v-power is good), and changing every 3k miles.
Old Jun 30, 2006
3k seems like a bit much for plugg changes and other guys are running this plugg as well.if it does not clear up, i will try this. i already thought of taking the IAT out of the pipe but i will have to get a new one since this one was made to be a perminate part of the pipe (it kept leaking boost out of it b/c the plastic was not hard enough to hold up under the psi i was running).
what heat,part # are the pluggs u recomend
my .2 is
have u plugged yours in to a OBD2 to see? it should read another code for exhaust issues.
the reason i think that is because it started when i put the sensor back in.
^^^^oh i see, u mentioned the code.well just look it up and u should see exactly what that code means.
Last edited by drunkenmagnum; Jun 30, 2006 at 12:48 PM. Reason: Automerged Doublepost
Old Jun 30, 2006
02BLKCIVIC's Avatar
yep I own a code reader. & the book with all the codes.
its a P0301,0302,0303,0304 & the random cylinder misfire on all 4 cylinders.
no other codes. I too have taken out my IAT when I replaced my intake.
Old Jun 30, 2006
the plug range for you, im not sure. may want to check around here and see what the turbo guys use or just send dezod a pm.
Old Jul 1, 2006
ok if u took out your IAT and r getting misfires, we could have the same problem.
Old Jul 1, 2006
well the iat is really hard to break, even if you drop and step on it i bet it would still work. and the iat does not contribute much to the a/f ratio. thats mostly the 02 sensor's job.
Old Jul 1, 2006
02BLKCIVIC's Avatar
when you say mostly...
what else controles a/f???
Old Jul 1, 2006
well the iat does, to a small extent. you dont have a cheap a/f gauge (non-wideband) do you? that thing really screws you over. not only ruining the 02 sensor, but the ecu will read the wrong voltage from it because of the gauge drawing on it.
Old Jul 2, 2006
02BLKCIVIC's Avatar
I did but I took it out
hmm.
Old Jul 2, 2006
well just cause you removed it, doesnt mean theres no damage done. you prolly need a new sensor
Old Jul 2, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
my thoughts exactly. why spread such nonsense gearbox?
Old Jul 2, 2006
because he has a turbo motor. depending on how he drives, I'd rather him have newer plugs in there than worn out ones. And for $2 each why not.
Old Jul 3, 2006
02BLKCIVIC's Avatar
It was misfiring WELL before the vafc2 or the stupid gauge...
Old Jul 3, 2006
did you ever do that compression check?
Old Jul 3, 2006
02BLKCIVIC's Avatar
yep all systems go!
Old Jul 3, 2006
well what were the psi values per cylinder? im just thinking of things that can cause a misfire. defective or worn plugs, coolant in combustion chamber, clogged injectors, faulty coil packs, and more. i would start one at a time and get some cheap copper ngk plugs and throw em in. then move on and treat fuel system with lubecontrol.com stuff, and test the coil packs.
Old Jul 4, 2006
The pluggs i am switching to cost about $50 for four (ik20's). i wouldnt want to put $2 pluggs in a engine i spent 4k on. but i will switch them out and see if that might be a problem. i have bee using bkr7e'sbut i think it might be time to freshin them up.
the reason i think the IAT sensor might be throwing it off is because it never misfired before i reinstalled it.
do u think a vacum leak might cause a misfire. i dont think it would but i figured i might throw that out there. also i have the comp cam but it has since been retuined. i dont know, i will keep trying diffrent things until i fix it. thanks for the help.
Old Jul 4, 2006
ctx66's Avatar
Those plugs are a huge waste of money and wont help fix your problem. Ngk's are excellent plugs and i'd continue using them. If they work in 11-12 second turbo dsm's with a lot of money invested in them, i see no reason not to trust them in your civic. It's entirely possible youre misfiring because of the plugs heat range. I'd go back to stock range 6, and see what happens then. What are your plugs gapped at?
Old Jul 5, 2006
02BLKCIVIC's Avatar
Id have to find my receipt gear.
SimpleUser
Apr 24, 2021 02:54 AM
EliseKStewart
Jul 15, 2015 11:11 AM
Jul 12, 2015 11:54 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Ccoop87
Jul 9, 2015 03:26 PM
