problem holding boost
Old Jun 29, 2006
evolutionmr's Avatar
evolutionmr is an unknown quantity at this point
Hey everyone. I'm having some issues with my turbo set-up. First off, I cant figure out what is wrong with it. When I start the car in the morning, it holds boost, but still dosent reach the setting that is set on the AVC-R. Its set at .70 bar. Then, if i run it hard 4-5 times, it stops holding boost all together. Now i cant seem to figure out what the cause of the problem might be. Is it a leaky wastegate? or is something wrong with the avc-r valve, is it because its heating up and not functioning right? Dezod help me out man, becauase all replacement parts will be ordered through u. I want it to run right, but theres lots of reasons why it might not be holding it. But i cant figure out why it holds only up .55-57 when it does hold. can anyone tell me where i need to start looking for leaks and what not.
Old Jun 29, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
do you have a boost gauge? what does the gauge tell you. my guess is that the wastegate spring is bad and you should get a new one probably. .7 bar isnt that like almost 9-10 psi? seems pretty high for a stock motor[im guessing your stock] i would turn that down a little bit. i dont know much about turbos, i just got mine, just my 2 cents
Old Jun 29, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
If it has something to do with heat then, rubber couplers and chargepipe connections mostlikely giving troubles.
Also, the wastegate deniately needs to be checked as well.
Old Jun 29, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Whats the WG spring?
1/2 a bar is about 8 lbs, which seems to be a reasonably common WG spring size. The BC may not be bleeding off any pressure.
If it stops holding boost completely, definitely look closely at the WG, its likely popping open or the heat is causing it not to seal.
Old Jul 1, 2006
thanks guys
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
dinsum
May 28, 2015 09:30 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
McD
Apr 16, 2015 10:46 AM
