anti-seize
Well i just changed out my plugs yesterday and I would have to say use anti-seize. There is a reason why mechanics all over the world recommend that you use it. Why risk the chance of your plug not coming out and stripping the threads.
Ive always used it since I had to help a friend replace the head in his 89 civic due to a stripped and rusted spark plug hole. antisize is worth it IMO, my father has been a mechanic for 30+ years and uses it too...
The answer should be NO. Anti-sieze alters the torque thats applied because it squishes. If you want the accurate value of torque to be applied to the plugs, then do as what was said above... install in remove them from a stone cold engine.
So long as they're properly torqued, they should come out when its time to change them again.
... but as you can see, there's arguement to the issue, and I think either way is probably considered acceptable, as both with and without do work.
emontgomery0227
Oct 14, 2012 05:14 PM
WaryDriver
Mar 18, 2012 06:55 AM
