HAHA, I Love DIY swaps **PICS ADDED**
Old Jun 22, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Well the K20a2 does infact fit into the civic engine bay . I know that it has been done many times, but trust me upon aproach you begin to wonder. Well it is 3:15am and I just put the last bolt in the subframe. I have to work at 7:00 am. I love DIY swaps
ID:	66869   Click image for larger version
Name:	engine 2 edit.JPG
ID:	66870   Click image for larger version
Name:	Engine 3 edit.JPG
Old Jun 22, 2006
Rennen's Avatar
New Mod on the Block
sweet. pics?
Old Jun 22, 2006
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
wow hot, is that all the parts you have in your sig?
YOU NEED TO DOCUMENT THIS!!!!!
Old Jun 22, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I Vote For Pics
Old Jun 22, 2006
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
on behalf of 7thgeners online, we deserve to see the pics....WE demand to see the pics.....AND, we want to see the pics, please give us some pics thank you i knw to give us bs cuz it was 3 in the morning....dont tease us
Old Jun 22, 2006
eye_see_you's Avatar
let the devil out
useless without pics
Old Jun 22, 2006
djmota's Avatar
did it go in from the top or bottom? take some pics.
Old Jun 23, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
you can do it both ways...
u seen my pics now its time to see urs.. lol
Last edited by xproductionz; Jun 23, 2006 at 12:26 AM. Reason: Automerged Doublepost
Old Jun 23, 2006
familycar's Avatar
depends on if she is laying on her back or stomach, but as far as pics go i doubt it everytime i do she makes me erase them LOL
Old Jun 23, 2006
djmota's Avatar
honey what is that little red light in the corner of the room.
Old Jun 23, 2006
familycar's Avatar
Old Jun 23, 2006
EMK20a2's Avatar
OK, OK LOL I will take some pics and post them
The engine went in from the top. I had problems clearing the ABS and the tranny mount bracket. I had to lower the tranny side alot and lower it in at an extream angle.
Yes those are the parts that I have in my sig. I will take some pics, but as those of you who have done it can attest it is a long enough process and sometime taking pics and documenting is the last thing on your mind.
Old Jun 23, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
where are u located?
Old Jun 23, 2006
EMK20a2's Avatar
one thing that I did notice is the RSX subframe bolts up just like the civic except for these two brackets that use to attach to the old subframe don't have a home. What have others done with these two brackets?? do I need them?? (you can see them circled when you double click.)
Name:	Engine 4 edit.JPG
ID:	66872   Click image for larger version
Name:	Engine 5 edit.JPG
Old Jun 23, 2006
EMK20a2's Avatar
Toledo Ohio
Old Jun 23, 2006
mines are just hanging there also... and the other swaps i have done also are just hanging there too.. lol
Old Jun 23, 2006
EMK20a2's Avatar
^^^^Funny, how you did not say if it was correct or not LOL . How did you do your fuel lines? I am to cheap to pay for the rsx ones from the dealer so I am going to use goodyear fuel injected line hose, the d17 clip on the fuel line and a fuel line hose clamp on the rail. I am going to try to get the line on the rail over the bead and then clamp it, but I am still a bit concerned about leaking.
Old Jun 23, 2006
lol... if u read my DIY i didnt even use the rsx lines they tell u to buy... waste of money and time... just take the clips off each end of the original fuel line and buy
Old Jun 23, 2006
EMK20a2's Avatar
^^yeah I read your DIY. The clip that goes to the fuel rail was broken on my engine. To get a new clip you have to by the entire lines. So based on your experiance do you think a clamp will work. I can't have it leaking because I wrapped my header. That fvcking thing would be a gaint wick if gas got on it.
BTW the Rsx radiator was a bit harder to fit in my car (required a small amount of cutting). The ECU was insanley hard to remove, and I wish that I would have removed the dash. I honestly was begining to think that you had David Blane helping you with you swap LOL
Old Jun 23, 2006
yea.. i know i mentioned it somwehre.. dont know.. but the EP and RSX radiator will fit perfect especially if you have a body kit.. but may require some trimming around the bumper area if u still have the stock bumper..
haha.. with the right tools i pulled the ecu out in 5 minutes.. u just gotta know what to take out... the hard part is figuring out how to put the ecu back in....lol
oh hey.. if u are using kpro.. connect the usb wire to the back of the ecu before putting the ecu back in... and tuck the wire somewhere to have easy acces... or else u wont be able access ur ecu unless u pull it out to connect it again.. FYI
Old Jun 24, 2006
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
congratz on the swap. Post up some times when you get a chance.
Old Jun 24, 2006
EMK20a2's Avatar
it was not anything with the body it was the framing that the radiator goes in. I had to cut it to get it in period. The stock bottle did not fit either, but I found a solution to that and I think people will like it alot. I will post it up when I am done. I would not want to ruin the suprise LOL
What did you take out to have more access to the ECU?? The thing that is in my way is the support bar that goes accross. Is there a good way?
Times?? do you mean track times or time to put the engine in?? If you are talking about track times I will likley never take it to the strait track. I autox ALOT and will take it to road courses. If I were to guess I would say that when I am done it should be around a mid 13 sec car with street tires and a low 13 sec car with DRs (I have shaved some weight).
As far as time to completion A LOT. I am a perfectionist, and do everything right. I will say that it is easier than the STI into a 98 Legacy swap that I just helped with (we did all of the wiring).
Old Jun 24, 2006
strange... i never had that problem...
Old Jun 24, 2006
EMK20a2's Avatar
It may be the difference in years I have an 04 civic. Your swap was on a 01-03 correct??
BTW what do I need to remove to get the ECU back in??
Old Jun 24, 2006
remove the 2 clips that hold ur glove box up... till it looks like this.
then remove the screw on with the arrows so the entire glove box comes off..
that will give you tons of room to play with
Old Jun 24, 2006
EMK20a2's Avatar
Yep, that is what I did. That damn bar is still really in the way though. I guess just work it until it goes into place though. Or come on man, you could give me David Blane's # and he could help me too. LOL
Old Jun 24, 2006
how is the bar in the way.. it should come all the way off.. lol
Old Jun 24, 2006
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
The bar should just slide down and out unless the relays are in the way.
Old Jun 24, 2006
EMK20a2's Avatar
No, I have all of that removed it is the main bar above that is in the way. You know the one that keeps ya alive when you wreck.
Old Jun 24, 2006
oh.. haha.. i know what u are talking about. i had to dremel off the side tabs on the ecu so i could shove it straight in... when u do the ecu wires face inside the cabin and the usb wire is in the back
