Relocating Brake Fluid Reservoir
Old Jun 21, 2006
Robertsk8's Avatar
Robertsk8 is an unknown quantity at this point
Exclamation Relocating Brake Fluid Reservoir
I purchased an eBay strut set for my 01 civic ex, though I need to relocate the brake fluid reservoir due to the strut bars clearance issue. I have disconnected the Reservoir from firewall/ strut tower assembly, but I am unsure of a proper place to relocate the Reservoir. Any ideas?
Old Jun 21, 2006
Rennen's Avatar
New Mod on the Block
thats not the brake fluid resovoir. its the clutch fluid resovoir. you can just bend the bracket back a little.
Old Jun 21, 2006
Robertsk8's Avatar
Not looking at the car now, but I believe the clutch resovoiris the one right behind the brake resovoir. But no matter the case the same technique applies.
Old Jun 21, 2006
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Like he said. the clutch is the small one in the front, the brake is to rear left of that.
Old Jun 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Clutch = small one
Brake = big one
You won't be able to move the brake reservoir, its pretty well attached to the master cylinder for a good reason.
Old Jun 22, 2006
Robertsk8's Avatar
Alright, the reservoir which i was looking at, the smaller one, also said brake on the cap, is in the way. I did remove it it from the firewall, but am unsure where or how to securely attach it lowered or away from its orginal spot due to the clearance issues.
Old Jun 23, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
post pics cause i dont see how this is so hitting ur brake.. mines used to hit the clutch (small one) so i just moved it down to the next hole right below it
Old Jun 23, 2006
Robertsk8's Avatar
that must be it then, xproductionz can u post a pic of? i did try locating to the lower but it would not fit securly and was pretty loose.
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
