Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
MEGAN COILOVERS DAMPER KIT (in-stock sale) $800 shipped
Old May 25, 2006
revautousa's Avatar
revautousa is an unknown quantity at this point
Fits 94-01 integra & 92-95 civic $800.00 (shipped)
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 12kg Front and 6kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All Hardware is Included
Old May 26, 2006
tyel03's Avatar
tyel03 is an unknown quantity at this point
megan kits for em2
do you have this kit for civic em2? ship to canada? postal code is R2X 1B4.
if so, how much it would be? thx
-Ty
Old May 30, 2006
revautousa's Avatar
Megan doesnt have a kit for the Em2 yet, I can get you a set of Tein SS for $1250.00 with upper pillowball mounts, $1050 without upper mounts, those are shipped prices.
Old May 30, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
megan has some for our cars. plenty of members have them on this site.
Old May 30, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Yup, I do, and I love em. My review is in the Suspension forum.
Old May 31, 2006
revautousa's Avatar
Do you guys need anything else for your cars? If you don't already know and if your in the area we now offer detailing, and we now have a certified mechanic. So if your car isn't performing right and you want the best performance out of your car or its just dirty we can help.
Sincerely,
Andrea from revauto
GolNat
Jan 12, 2021 09:06 PM
JKWood
Jul 28, 2015 03:45 PM
EM_WON
Jul 22, 2015 06:49 PM
