V-afc2 and rsx-s injectors
Old May 24, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
I have 6psi with t25 ... i have rsx-s injectors... here is my question... can i controll the injectors with the v-afc2 or can i just adjust the map.... oh yeah how well does the v-afc2 work with missing link? Thanks
Old May 24, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Missing link and V-afc work separetly and will work fine.
V-afc is the worst method of controling fuel on turboed car. V-afc can add fuel with rpms, but it cant add fuel based on psi.
If you are short on cash,
You might want to look for used TSI injection unit. It can add fuel by psi and by rpm and it has 2 injectors that are adding fuel.
Used piece should cost about $200.00
Old May 24, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Stupid question: What is a "missing link"???
Thanks in advance!
Old May 24, 2006
BoostedVik's Avatar
When you add a Turbo to your engine, The MAP Sensor (Manifold Absolute Pressure) which is designed to read Vacuum Pressure, will read Turbo Boost and throw a Check Engine Light. Missing Link prevents the Computer from determining the correct air flow and results in poor engine performance. The Missing Link intercepts the Boosted air flow before it hits the MAP Sensor. This fixes Check Engine Lights, Helps the Computer to Maintain Proper Air/Fuel Mixtures and provides smooth Vacuum to Boost Transitions. The Missing Link installs in 5 Minutes with common hand tools.
source: racingworks.com
Old May 24, 2006
BoostedVik's Avatar
tuning the tsi injection unit i heard is hard and no shop here does it.... apexi v-afc 2 can do it by rpm and its fine... as long as it adds more fuel ... but you said missing link and v-afc 2 with 310cc is cool...?
Old May 24, 2006
02BLKCIVIC's Avatar
Thank you again SIR!
Old May 24, 2006
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
i don't think safc and missing will work well on turbo car. if you are using safc hack method, the tuning has to be really precise, because safc needs to manipulate map sensor reading to adjust the fuel.
I will not recommend safc hack either, because it will advance your timing a lot when you lean the fuel out with rsx injectors.
Old May 24, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
hmmmm...interesting....how many members are running this type of setup? with the afc hack?
Old May 24, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well.. i was turboed with missing link and the vafc2 setup for 2 years till i got rid of the setup
Old May 24, 2006
^^^^how'd that go? how hard is it to tune with the v-afc...did you use the hack? xproductionz?
Old May 24, 2006
what HACK are you referring to... all i did was connect the vafc and went to my local tuner and bamn.. my a/f was tuned.. other than that you can tune it your self if you got a a/f gauge but that should only be a temporary thing... lol... not recommended
Old May 25, 2006
BoostedVik's Avatar
you had missing link and v-afc... did you have any bigger injectors?
Old May 25, 2006
oh.. lol.. it was a custom turbo setup with type s injectors.. vafc2... and the missing link.. at the time dezods kit wasnt even out yet so i had really no option on the kit i could use.. SF was just making there kits available...
Old May 25, 2006
BoostedVik's Avatar
sweet... you are one of the 1st to boost!!!?
Old May 26, 2006
i wouldnt say first.. im sure there were others out there that must have done it.. of course since they were already making missing links for our cars at the time.. lol
Old May 26, 2006
lol..If you know how to use a cell phone - you know how to play with tsi injector box...No special training needed what so ever....
re: bold text
Wrong, as someone mentioned - you can use it as a temp solution.
You need to understand that at 5000rpm you can either bee at 10psi or you could be at vacuum, but v-afc will continue dumping fuel to the engine. Not very good for spark plugs, o2 sensor and "general driving enjoyment" (engine will run like crap)
Please read this fine print:
Since you already have rsx-s injectors, then spending $200+ for v-afc, I cant concider this as a sound investment, where you can add another $100-some to by e-manege box and then have practicaly unlimited tuning capabilities...
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
