what amps can power 2 jl audio w6?
Old May 17, 2006
2k1excoupe's Avatar
2k1excoupe is an unknown quantity at this point
i have 2 10 inch JL audio w6.. i have an audiobahn 800rms amp i believe the model # is A8000T.. would that b enough to bump my jL audio speakers?? if not.. does anybody have any amps that can power them??
i would preffer pms.. i have a horrible memory..
Last edited by 2k1excoupe; May 17, 2006 at 03:37 AM. Reason: Automerged Doublepost
Old May 17, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
A JL 1000W mono block amp would be the best bet. since those are 3 ohm speakers, and unless your amp is 1 to 4 ohm stable you may run in to problems later on.
Old May 17, 2006
eye_see_you's Avatar
let the devil out
jl 500/1 , jl 100/1 just to start with I have a jl 500/1 myself on two 12's and it pounds my speakers
Old May 17, 2006
2k1excoupe's Avatar
the audiobahn amp is 2ohm stable.. what kind of problems would u run into? the amp i have now is 800rms at 2ohms and 400rms at 4ohms.. would they atleast push my speakers 50%??
they'e selling me another audiobahn amp thats 1x800rms at 4ohms stabe.. they're askin $160.. is that a good price for an amp that would pwer my w6s?
Last edited by 2k1excoupe; May 17, 2006 at 10:37 AM. Reason: Automerged Doublepost
Old May 17, 2006
burke420's Avatar
The World Is Yours!
if you end up buying tht JL 1000.1, you WILL NEED a H.O. alternator and a 2nd battery. i have the jl1000.1 with a 13w7, it was a crazy setup till i get the alternator and battery in the back!
Old May 17, 2006
WhiteRabbit's Avatar
its a tough call. Those w6's are dual 6 ohm drivers. this gives you three potential wiring configurations:
1.5 ohm
6 ohm
24 ohm
theres no real good answer for you. neither of yoru two amplifeirs was designed to handle a 1.5 ohm load. That being said, your current amp (800 watt 2 ohm amplifier) as the best shot of being able to remain stable powering those drivers.
the best bet is to go with an overbuilt 1 ohm stable amplifier, but in a pich, that often isnt financially feasible. In which case, I'd say your best bet is to stick with what you've got.
Old May 17, 2006
AlienX's Avatar
AlienX will become famous soon enough
jl1000.1 would be your best bet. Those amps run at 1000watts no matter on the ohm level. So you can run it at 26 ohms and it will still provide 1000watts of RMS power..
Old May 17, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
O Rly?
Old May 17, 2006
let the devil out
my jl 500/1 is 500 watts @ 1.5 ohm ~ 4 ohm stable but it tested from the factory at 768 watts and a firned of mine has a jl 1000/1 which is simalair to the same specs expect wattage and his amp tested way over 1000 as well.. for two w6 a 500/1 is more than enough unless you plan to compete
Old May 17, 2006
diskreet's Avatar
I would personally do 2 500/1s or a 1000/1.
JL stuff is top notch, ESPECIALLY their amps. The 500/1 is a work of engineering art.
Old May 17, 2006
AlienX's Avatar
go to the website
http://mobile.jlaudio.com/index.php
look at the spec sheets and read some of the features. They try to say things in plain english for you and I think you will be amazed at the JL difference.
Old May 17, 2006
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
JL all the way for sho I way 2 W3v2 12 and a 500/1
Old May 17, 2006
nick95673's Avatar
http://mobile.jlaudio.com/pdfs/6892.pdf Page 6 far left first "! important" @24ohms you would have about 200W RMS which is really good but it is not 1000W RMS.
Old May 17, 2006
diskreet's Avatar
LOL I am running 2 10" W3v2s (but in the JL HO box) with a 500/1. It POUNDS but is supremly precise for the price. I have the loudest AND cleanest subs out of all my friends. JL FTW.
Old May 17, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
i would call jl there customer service is the **** and ask them what they think
Old May 23, 2006
Rufus's Avatar
I run 1 500/1 and it pounds. Ask anyone in the AZ forum. I run 2 Diamond Audio D9's
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
