Need Help Radio won't turn off
Crack kills... But then again... So do I...
Well my battery took a crap on me this past weekend so I went out and bought a new Duralast Gold from Autozone and it works great... Possibly a little too well... I had a car show on Sunday everything was great, but when I parked my car in the garage afterwards, I killed the engine, pulled the key from the ignition, but the radio continued to play. I had to disconnect the harness on the radio to cut the power. Does anyone have any idea as to what I should do. I'm already going to check out all the lines and make sure there isn't a bad connection, but I can't figure it out. Please help...
Re: Need Help Radio won't turn off
Hello,
I have a 01 LX with the same problem. A few weeks ago my radio was working fine and out of the sudden it reset itself and asked me for the code. This week, the dealer entered the code and worked fine.
After about 1.5 hours of being on (I drive a lot for work) it got stuck and wouldn't turn off, change stations or take CDs. When I stopped and took the key off the ignition, it stayed on. I had to disconnect the - wire of battery to reset it. I had to enter the code again and worked for about 1.5 hours. Yesterday, the same thing happened and had to disconnect the battery.
Does anyone have an idea of what is causing this problem? Any help is really appreciated.
trellex
May 24, 2015 04:39 PM
ayoitzjulesdx98
May 13, 2015 08:31 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
