12" 1000watt subs, 2000 watt amps dropped price
2 1000 watt XSite 12" dual voice coilovers brand new never used $80 each or both for $150 free shipping
specs:
• PHAT 2” FOAM SURROUND
• NON-PRESSED NON-TRANSFER PAPER CONE (KM3 COATED
FOR VIRTUALLY NO DISTORTION)
• PROGRESSIVE RATE DAMPER W/SPRING-WOVEN TINSEL LEADS
• HIGH STRENGTH TWO-LAYER SURROUND FOR ENHANCED CONTROL
• CUSTOM TOOLED XSITE DIE CAST BASKET
• DUAL 4 OHM (2 OR 8 OHM OPERATION)
2 2000 watt Xsite mono block class D amps brand new never used $250 each free shipping
specs :
Class D Circuitry
•Multi-Stranded Power
Supply Toroids
•Blue Anodized Heat Sink WIth
Lazer Diamond Surface
•Brushed Aluminum Case
•Remote Bass Control
•THD:0.05%
•S/N Ratio>100dB
•Variable Sub Sonic Filter
15Hz-40Hz
•Variable Phase Shift: 0-180°
•Variable Bass Boost Control:0-18dB
•Frequency Response:25Hz-200Hz
•Tiffany-Style Input & Output RCA Jacks
•Milspec Double-Sided Epoxy Circuit Board
•Data Link Port (Combines 2 Amplifiers
2 kicker pro comp 300watt subs used but in good condition $100 free shipping
for information on the xsite stuff go to www.xsiteusa.com
xsite is made by audiobahn.
no one ???
somebody has to need system equiptment ......
IF SOMEONE TAKES THE 2 SUBS AND 1 2000 WATT AMP FOR $400 SHIPPED I WILL THROW IN AN XSITE 1.5FARAD CAP FOR FREE ......
for an extra $50 bucks ill ship to cananda so for $450 you can get a 2 subs an amp and a cap...
Bump
specs:
specs :
Class D Circuitry
Supply Toroids
•THD:0.05%
•S/N Ratio>100dB
15Hz-40Hz
no one ???
Bump
Last edited by mndthegap1; Apr 28, 2006 at 11:46 PM. Reason: Automerged Doublepost
they are a sister company of audiobahn, the people that make audiobahn and alphasonic make the xsite.
here are pics of them on a fiberglass box, again they where just taken
out for the pics. that is my box, but i cant use em cause the baskets on the subs are too big for the premade box, and the inputs/outputs for the 2000 watt amp are not in the front for the 2k amp like the box is set up for.
the front amp is a 400watt which im keeping.
What_It_Do
May 10, 2015 05:31 PM
PimpBot5000
Nov 26, 2001 07:15 PM
JjAnGPeETuL
Nov 8, 2001 02:16 AM
