Advice on tools and spark plugs (updated u gotta read this)
Update:
Im done everything
Plans
Ok this weekend im planning on doing alot:
The list as of now is:
Brake Caliper and Drums Paint (Done)
Change the Brake Fluid
Change the Sparks Plugs (Done)
Change the Oil (Done)
Now i need to know wat special tools i might need i have all the usual wrenches and sockets. (if u wanna list them all that would be nice)
As well wat sparks plugs and wires i should buy.
And if u wanna through in preference for some good oil.
I have an 03 lx Coupe
thanks everyone.
Im done everything
Plans
thanks everyone.
Originally Posted by luvvegas777
ngk spark plugs, our cars do not have spark plug wires. 5w-20, if you do synthetic then you must do synthetic oil for the life of your car. Mobil 1 oil is good.
you need a 5/8" sparkplug socket, a snazzy craftsman LOCKING extension bar (it saves you the trouble of having to fish the socket out of the spark plug tube after the plug doesn't release from the O-ring but the extension comes out of the socket) and a 4" or larger C-clamp for the brakes.
Civicforums Junkie
Change the Oil
thanks everyone.
Change the Oil
thanks everyone.
I Hunt Goats, Rams, And Mustangs.
and if you have to fish the spark plug out, easy way is just to take a hose and push it down on and pop it comes out. but on a side note if you ever want to covert your car to have spark plug wires you can get some Nology wires lol, as for why? I have no idea.
Originally Posted by dariusld
All these things a very easy, except the changing the brake fluid part. Make sure you change the spark plugs when the engine is cold. I love when people do it themselves, but the brake fluid might be over your head. Tell us how it goes and if you run into any problems, just ask.
Crayons taste like purple...
best tool I got for plugs is a 8-10" extension bar with a wobble socket at the end (all one piece)...at harbor freight....just glued the boot in with "gorilla snot"
if you've never changed the brake fluid yourself before I suggest steering clear of that and letting someone do it who knows what they're doing...
my friend knows wat he is doing jus never done it on a civic and cuz we are kinda strapped for time he wants me to have all the tools we need ready jus need to know where the bleeder bolt or screw is and what tool i need for it
he used to work at sears automotive and has experience doing this stuff
thanks for ur concern though
Just make sure on the brk fluid to start at the right rear then left rear then right front then left front. and make sure the blleder is closed before your partner lets off of the pedal or air will enter the system and you'll have to bleed it out, bleeder screwws are almost always 8 or 10 mm
THanks everyone i am done got the bolt out and the guys at the Canadian Tire shop gave me the bolt i needed (saved the day)
that was hectic but ill defintely do it again i Learned alot
danace99
23
Jun 28, 2015 08:49 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
