engine bay cleaning question
Old Apr 16, 2006
brendan04's Avatar
brendan04 is an unknown quantity at this point
i just got back from a trip to mexico and my car got pretty flithy driving down there and i was wondering what you guys do to clean your engine bay. Mine is soo dirty. Thanks
Old Apr 16, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I wash it down with a normal car wash soap, using a soft bristle brush meant for wheels. Then I use a product called Pig Spit. Click the link in my sig for pictures of my engine bay using that stuff. Awesome
Old Apr 16, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I hit the local do it your self car wash station hit it with the pressure washer, then on anything black add a little armorall tire majic fome stuff. Makes it nice and purdy! then shine the crome with some window cleaner.
Old Apr 16, 2006
soccer1cb's Avatar
soccer1cb is an unknown quantity at this point
You hit your engine bay with the pressure washer?!?!?! Is that safe? If so I might have to do that more often....
Old Apr 16, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
when the engines cool, i put a plastic bag over the end of the intake tube. then i spray down engine area with a citrus degreaser. then i just spray down the engine bay with a pressure washer, careful not to spray down any area for too long, i keep moving around a lot. and after that, youre all set. you should try to dry whatever you can, and let it sit to air dry.. but it wont be the end of the world if you dont. oh yeah, after i wash my engine i usually wash my whole car.. because the degreaser and all the crud can get on the paint.. and i dont wanna risk it doing any harm
Old Apr 16, 2006
i would never spray water in the engine bay. all i use are some cloth, plastic protectant (turtle wax), orange degreaser, and metal polish. thats all you need to get it looking good.
Old Apr 16, 2006
soccer1cb's Avatar
Hmmm...so no harm from spraying water into the engine bay?
Old Apr 16, 2006
Hoosier282's Avatar
Hoosier282 is an unknown quantity at this point
Use degreaser, spray it in there, and then spray the engine bay down with water. I used it and my car still runs.
Old Apr 16, 2006
I never have had a problem but i dont spray water on a hot engine. Its always cool before i spray it. It helps get rid of all the oils and stuff on the engine from spills or what not. Dirt flys away. and its bling bling when im done. Look at some of my pictures and just see how clean the engine bay is.
Old Apr 16, 2006
MYK1013's Avatar
i dont wanna risk anything by spraying h20 on the bay. I just use soap water, used toothbrush, some effort and then I top it off with armor all.
Old Apr 16, 2006
Just dont spray the intake and you'll be alirght lol.
Old Apr 16, 2006
v8eaterokv6's Avatar
i have a new home do u
just spray the engine with some degreaser let it sit a few minutes then hose it down you wont hurt anything. its a car it was designed to get wet
Old Apr 16, 2006
actually it wasn't. look at all the splash guards above the fender, under the car, and the hood, designed to keep water away from the engine and electrical components
Old Apr 16, 2006
LiKEaFeRiO's Avatar
1. Spray Simple Green
2. Wait 10 minutes
3. Pressure wash
4. Dry
5. Tire shine (spray type)
6. Admire and try not to get a hard on
There really isn't anything to cover unless you have an intake or other mods that shouldn't get wet.
EDIT: You should check your engine bay for any loose and exposed wires. I will not be held responsible for any problems you may develop from failure to properly check your car thoroughly.
Old Apr 16, 2006
brendan04's Avatar
hmmm so power sprayer is fine as long as i avoid the intake...ive always avoided using it cause i didnt want to mess anything up
Old Apr 16, 2006
LiKEaFeRiO's Avatar
You don't want to shoot it close up because too much pressure might cause trouble.
Most DIY carwashes have the "streak free" rinse option.
It has less pressure.
You can use that if you are scared.
I've done my method every month for the 5 years and 107,000 miles I've owned the car with no problems at all.
Old Apr 17, 2006
CenZ's Avatar
PWIT
have you ever popped your hood when it was raining out after driving? your engine is soaked, spray some water in there wont cause any problems. dont worry, i didnt even cover my intake, and my car is fine.
Old Apr 17, 2006
Spraying water in an engine bay wont hurt it. If you dont want to worry, do to a rush job and spray the engine and then take off driving like a bat out of hell. Give the engine a little time to dry and use a shammy or something. Make it bling if your going to clean it.
Old Apr 17, 2006
soccer1cb's Avatar
Well my bay def. needs a good cleanin......thanks for the "Engine Bay DIY clean"
Old Apr 17, 2006
i pop the hood alot after its been raining, and its bone dry inside except the edges.
Old Apr 17, 2006
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I have to add my experience. I have a 01 EX with an after market grill and have driven in really bad rain for hrs. (people in the Central Valley of CA know what I mean) Get Home and pop the hood and the engine bay is wet how ever not completely because of the heat radiated from some of its componets.
Presure wash is the easiest way to go, imo better way to go too.
As long as you follow simple rules you should be ok. `1st wash when engine is cool/cold. 2nd cover intake, even stock. 3rd don't spray directly into sensores. and 4th don't spray for a long time in one spot remember to keep moving around the engine bay.
Old Apr 17, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
why not use brake cleaner to get rid of the greese and dirt. works for me
Old Apr 17, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i have been cleaning my engine bays with that engine foam cleaner u buy from autozone and spray with water for 10 years now and have never ran into a problem with the car.. well my 2 cars that i own at least... if you drive in the rain for s short period of time then it might not be as wet.. trust me though ur engine bay might not appear wet cause the heat will dry it off while ur driving
Old Apr 18, 2006
BoostedVik's Avatar
true true
Old Apr 18, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
ok i'm planning on cleaning my engine too...i have an 05 civic. what parts will i cover in the engine bay so i wouldn't damage anything? thanks
Old Apr 18, 2006
dude read this thread its all here
Old Apr 18, 2006
BoostedVik's Avatar
dont be mean ^^^^
this is what should be done. cover the intake, and battery with plastic bags,
spray some degreeser and let it sit, preasure wash it and let it dry... some people pray the wires with lubrication, such as wd-40, not sure why, but i do it anyways....
hope it goes well
Old Apr 18, 2006
uk_surfy's Avatar
uk_surfy is an unknown quantity at this point
you shouldnt really spray water in the engine bay cause of the electrics, can kill the distributer, over here in the UK we have steam cleaners that get rid of all the engine bay dirt, dunno if you guys do tho!!!
Old Apr 18, 2006
rjngo's Avatar
Originally Posted by BoostedVik
dont be mean ^^^^
hope it goes well
thanks a lot man!!!
Old Apr 18, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Don't aim directly at the alternator haha.
