Archive - Wanted Parts (WTB's) Let everyone know what parts you want to buy (WTB) and members will respond to your request. Include details of the correct application (DX or EX, 7th or 8th generation)
Wanted: Main driver side window control
Old Apr 3, 2006
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
Dead or alive, 2 dr or 4 dr. Send me a pm let me know where it is so we can arrange shipment
OK, if you have a right passenger side control, that will do also. It doesn't need to be the main control.
going to:
gahanna, ohio 43230
Thx
Old Apr 3, 2006
going to:
gahanna, ohio 43230
Thx
Old Apr 4, 2006
bumpity bump bump - bumpity bump bump - easters on its way....
Old Apr 10, 2006
If you have a passenger side single control, let me know. that would work too. Please, i need one of these things.
Old Apr 16, 2006
Update.
I need the driver side main control unit. either a coupe or sedan will do, because i will remove the electronic piece that i need and insert into my control.
Please, please, please...
I just want to get my drivers side door handle put back together, with the window controls working!!
Old Apr 16, 2006
LiKEaFeRiO's Avatar
I have a sedan main control unit.
My rear driver's side window is dead.
I'm not sure if its the main control or the rear driver's control that's not working.
I'm 80% sure its the main.
Um...$20 shipped?
Old Apr 17, 2006
Um...$20 shipped?
Sure i will take it, i sent you a PM.
you can look at your main control board rather easy if you disassemble. i could easily see the fried portions of mine so you could too. you could also apply 12volts to your window regulator to find out if the regulator is OK. but in summary, its my guess that it is either of these 3 items, front switch, rear switch, or regulator.
dont forget, in the process of my ordeal, i blew a fuse. and they are up under the steering column. likely you will have blown one of them too. they are kinda bit(hy to get out, there is a removal tool up front under the hood in the fuse box on the passenger side, close to the front headlight. that will help you remove the fuse up under the steering column, then you can inspect the fuse to see if its burnt.
Old Apr 26, 2006
yup, it was blown just like mine. it was fried.
i rep'd you for that!!!!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
sonsonzai
Nov 4, 2001 12:52 PM
