cooling...
Old Apr 1, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
cooling...
Boosters, what are u guys running to keep the engine cool and stablised? any cooling system upgrades thats needed?
Old Apr 1, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Havent had any ugrades for mine.
I run 9-10psi on t25.
Old Apr 1, 2006
C2i0v0i1C's Avatar
SuperMODrizd
i have an electric slimmer fan and a thicker aftermarket radiator from a 99-00 si
Old Apr 1, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I hard wired my fans so i can A) turn them on while ther car is off, or B) while the car is running, they will turn on threw the tempature swich *normal operation* or C) be off completely for cold cold days. I have a wireing diagram if you want one. Its not that hard you can even uses your stock relays if you want.
Old Apr 2, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
The radiator is oversize, but the car needs more oil if you're gonna run it hard.
Old Apr 2, 2006
civic01vtec's Avatar
Not a damn thing.
Old Apr 3, 2006
jacky599r's Avatar
huh, nt even a thermo stat upgrade wat so ever? i run an oil cooler thats all. im abt to run it hard to some places.prolly holding 140km/h or so. i dont gert cold days. its 32 deg C avg here.
Old Apr 3, 2006
Jap-Euro Fusion
DO NOT run a cooler t-stat. Hondas need to run a little hot. Its not a ford, the clearances in the engine are tight, you need water above 200 and you need the oil about 205-220 for the car to run right.
Old Apr 3, 2006
ncirom2003's Avatar
are there any oil cooler kits out there that screw onto the filter spot and also relocate the filter?
i cant do the oil cooler if it needs to be "T'ed in" to the sending unit feed hole.
Old Apr 3, 2006
Jap-Euro Fusion
You don't install a cooler with the pressure sender. That would be like cooling through a straw. The cooler must be installed though the filter landing in some way or another. You have to DIY the kit with a sandwich or blockoff plate, big lines (-10 or larger) and a cooling grid. Go as ghetto or expensive as you want.
Old Apr 4, 2006
turboengnr's Avatar
DONT PANIC
The stock honda radiator is actually a pretty efficient brass-copper cored one. They cool rather well. They will cool much better than an aluminum radiator of the same dimensions and fin density.
Old Apr 9, 2006
jacky599r's Avatar
hmm.i was thinking of upgrading my radiator. its kinda hot here. 30 over deg C. so ive to keep things real cool. its like an oven in my engine bay. any1 has any idea which radiators to turn to? or have any other radiators that u guys are running other then stock?
Old Apr 9, 2006
get a vented hood
Old Apr 9, 2006
blouisgod's Avatar
Life Begins > 6800rpms
ive got a vented hood, mesh grill without a shroud and a manual fan thats on automatically by default and just regular coolant changes to keep cool with 95 F temps. im looking at a high output fan right now, about 1800 cfm just to be good with added heat from the boost.
Old Apr 9, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I've upgraded to an koyo racing radiator and replaced 2 my stocker fans with slimlines.. more room and flow more air. No overheating problems here.
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
hell, i have the stock radiator, stock fans, and a very large intercooler in front of my radiator blocking the airflow. And i live in the middle of the mojave desert where it often reaches 110*-115*F. And i dont have any overheating problems.
The stock cooling system is very well designed. If the completely stock coolant system can keep my motor running at normal temps, then it should be able to do that for everyone.
If your car overheats, there is a completely different reason for it. And if you are looking for a larger radiator just because the engine bay gets hot, then you are buying something that will not help out a bit. Even if you get a radiator that is as large as the car, with an insane fin density...... the engine bay and the motor will still be the same temperature because the thermostat will simply close, causing the coolant to heat back up to normal temps.
there are reasons for going with different things. Some people on here do road racing which can put a lot of stress on the coolant system. Thats when you would buy a better radiator for preventative purposes. Some people install slimline fans, but thats mostly because the stock fans get in the way of most turbo systems.
Old Apr 9, 2006
what about hi revving up a mountain
Old Apr 10, 2006
turboengnr's Avatar
DONT PANIC
mine was fine.
I drove up to Mammoth Mountain in my civic while it was running about 10 psi. I went from 2300 ft to 9,008 ft over the course of about a 1 hour haul up a grade. I was in boost just about the entire time, and at 4000 rpm or higher. And i never had any problem with my car overheating.
I was worried about it, and nervous the whole time. But it ran great the whole way up there
Old Apr 10, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
the stock system is fine if people can take there cars road racing and not worry about overheating u should not have to think about it.
Old Apr 10, 2006
7thGenerasianCivic's Avatar
Do the JDM raised hood. AHHAHAHAHAHA
Old Apr 11, 2006
jacky599r's Avatar
hmmm. i was thinking abt getting a thermostat. and are there more effective coolants out there? i raised my hood though. a couple of washers. thats all. but hell. this place is hot and humid. thats y im worried.
Old Apr 11, 2006
Jap-Euro Fusion
DO NOT change the T-stat. Those 160 deg ones are bad news. You need a honda to run semi-hot for it to run best. Oil a little over 200 and water a little over 200 is right in the ball park.
Run straight distilled water, it cools better than antifreeze. Throw in a little Water Wetter to keep the pump bearings happy.
Old Apr 11, 2006
jacky599r's Avatar
ha. so stock it is eh?
distilled water.water wetter. coolant?
Old Apr 11, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
One of the main reasons hondas are so great.
Old Apr 11, 2006
ncirom2003's Avatar
50 50 coolant water, you need the antifreeze
Old Apr 11, 2006
Jap-Euro Fusion
You only need antifreeze so the coolant doesn't freeze. If its hot year round then you don't need antifreeze, you can run straight water. For the benefit of the water pump, its best to put some lubricating additives into the water like Water Wetter or Purple Ice, but you certainly don't NEED a 50/50 mix. I would guess that mine is about 75/25 Water and AF respectively.
Old Apr 11, 2006
ncirom2003's Avatar
you also need antifreeze because the stuff in it helps prevent oxidization in the system, rust isnt good in the system. and no it doesnt absorb the heat, the water does, but antifreeze brings up the boiling point of the water.
at least do a 30/70 or something close to that. its not good to run straight water, your only gonna cuase problems in the future.
Old Apr 14, 2006
turboengnr's Avatar
DONT PANIC
you need to run a certain percent of antifreeze in the system. If not, the water can cause the aluminum to oxidize and can clog up the radiator in a matter of weeks.
Old Apr 14, 2006
ncirom2003's Avatar
^good to see im not the only one telling them this.
Old Apr 14, 2006
jacky599r's Avatar
cool. going to get it done later.thanks dudes.
no particular branding?
