A whole new meaning to Electric Supercharging
Old Mar 30, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Dont know if this one in particular has ever been posted.
Check this out:
http://www.turbomagazine.com/tech/0406tur_knight/
thought it was kind of funny, but cool at the same time. Now some of yall might be able to adapt a simi-cool super charger to your car with this idear!
Old Mar 30, 2006
turboengnr's Avatar
DONT PANIC
thats been out for a few years.
Only lasts about 15 seconds at a time
Old Mar 30, 2006
I know.. but still, its kind of crazy, thats a little bit different than that cheese ball 1 motor hair dryer thing you find all the time.. Thats a M46 addapted with 3 starter motors.
Old Mar 30, 2006
turboengnr's Avatar
DONT PANIC
those starter motors have a Ton of torque. Much more effective than a little POS bilge pump or whatever they use.
Old Mar 30, 2006
Exzactly, but he has to have 2 batterys in the trunk for when he opperates that thing lol.
Old Mar 30, 2006
turboengnr's Avatar
DONT PANIC
yup. Thats the downfall of that system. Like any other method, it takes power to make power.
Old Mar 30, 2006
Well sort of theres one system to get horse power and not loose hp.. The EPS for an EP3! lol. it only uses power when needed and you save 5-7 of normaly "hydrolic" system .
Old Mar 30, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
sounds like this is a couple years from being a decent option
Old Mar 30, 2006
diskreet's Avatar
Honetstly this is useless in our cars. If you can get say 15 seconds from it, then you are not even able to keep it running for a full 1/4 mile pass. On top of that try tuning with that.
Seems like a great idea for 1 guy to do, but in the end its not worth the work.
Small turbo would be the best bet still
Old Mar 31, 2006
turboengnr's Avatar
DONT PANIC
If you can add fuel, it could make a big difference on the civics.
I dont remember how much off hand, but i think it will move enough air to make about 5 psi of boost on small displacement motors. That is enough to put you in the 14's if you are a good driver.
Old Mar 31, 2006
Michalo187's Avatar
Abortion Survivor
Yeah i also remember reading its like if you run 5 psi. Someone should try it and see how they do.
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Skunkone
Sep 24, 2015 04:38 PM
beanhead
Sep 24, 2015 12:04 PM
blizza
Sep 20, 2015 04:09 PM
tomas6791
Sep 11, 2015 06:47 PM
