Squeeking noise when bouncing front end
Old Mar 29, 2006
PrYnCeQT's Avatar
PrYnCeQT is an unknown quantity at this point
I changed my shocks to Tokico HP last year with stock springs, I notice recently that when I go over a bump the car's front driver side suspension squeeks. Does the same thing when I bounce the car on that side too. What can it be? Shocks, springs, etc? Does it need greasing or is something wrong and needs attention? Thanks.
Old Mar 29, 2006
Zzyzx's Avatar
Autocross Junky
It could be some thing as simple as a bolt being loose. so start there.
Old Mar 29, 2006
zen_master's Avatar
z...
i think im experiencing this too with my stock suspension.....front, driver side...
do you know which bolt commonly loose and should be my first thing to check out?
Old Mar 30, 2006
Zzyzx's Avatar
Autocross Junky
Well check the bolts on the upper mount then check the bolts on the knuckle
alternatly it could be that the spring has shifted slightly and is now rubbing against something that it shouldnt.
Old Mar 31, 2006
legend921's Avatar
legend921 is an unknown quantity at this point
It could most likely be the rubber on the top mount moving with the spring. I have the same problem, and all you need to do is just lube that rubber between the top mount and itself. It will go away in time, mine is just starting to be random now so I don't really care much.
Old Apr 1, 2006
hdave's Avatar
hdave is an unknown quantity at this point
i have the exact same problem
im going to be taking it apart and retightening it all and greasing the hell outta that part
ill let u guys know how it goes
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
RyanCoult
May 29, 2015 09:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
