idle tach readings
Old Mar 23, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
idle tach readings
anyone know what the idle speed should be for an automatic ex? is it 650 to 750?
Old Mar 23, 2006
TheSmuggler's Avatar
Mines like mad low, around 500
Old Mar 23, 2006
shroomster's Avatar
thats what i know but now that problem I was telling everyone about, its doing it worse when i go in reverse, if I let off the gas and let it roll, it drops to the 500 mark and below and does the sputtering thing.
Old Mar 23, 2006
You have an intake right? You sure you MAP sensor is still pluggd in?
Old Mar 23, 2006
shroomster's Avatar
why wouldn't it be? I just have the aem sri.
Old Mar 23, 2006
Do the idle learn. Auto should be right around 700rpms in neutral and 650rpms in D. There is a +/-50 variance per the manual, but those values should be close to what I posted. If you have the 03+ cluster like i do, there is no way to tell without some sort of digital readout.
Old Mar 23, 2006
shroomster's Avatar
never have done an idle learn. just disconnect/recoonect the battery and then turn the car on right?
could you clarify this
you always relearn the idle when swapping the throttle body. after unplugging the battery, you have to let it idle for 10 mins once the car is warmed up. its easier to drive the car first upto temp, then pull the battery for 10 secs, then start the car and let it idle 10 mins. you can't use accessories or press the gas during this time.
cuz like my last post I thought you just pull the batt neg cable for 10 seconds
then turn the car on w/o anything.
Last edited by shroomster; Mar 23, 2006 at 12:36 PM. Reason: Automerged Doublepost
Old Mar 23, 2006
there's nothing to clarify. just do what it says. drive car to warm up, pull battery or fuse, put back, start car, let run 10 mins without any accessories or gas, turn off, turn on and drive.
Old Mar 23, 2006
You know whats weird, sometimes when I start my car and it turns on, it liek feels like it's gonna die, it shutters REAL bad and the whole car shakes, then it comes to life. Really weird lol. Only happens every once in a while though, only on cold starts.
Old Mar 23, 2006
ya mine did that with iridium plugs, sometimes it wouldn't even turn over just crank forever. changed to ngk vpower copper and it never does it anymore.
Old Mar 25, 2006
So you think my plugs have somehow fouled? I haven't changed them (shame on me) and I'm at 39 on my 02.
Old Mar 25, 2006
i wouldn't be surprised.
Old Mar 25, 2006
I hate you :-P I'll hve to have it looked at, even though I'll just put in the normal oem ones again, whatever they are.
Old Mar 25, 2006
well oem is double platinum which is expensive and not really a good plug even. why dont you just try the vpower it takes 10 mins to change?
Old Mar 25, 2006
I wont be keeping the engine for that much longer lol
Old Mar 25, 2006
shroomster's Avatar
well, it's been longer than 10 minutes now, you have the new motor yet? hehe
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
htowncivicEX
Nov 13, 2001 04:30 PM
