I Need Major Help Please!!
Old Mar 19, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
Exclamation I Need Major Help Please!!
Ok here the problem. I hit a pothole or something, i never saw it, and i think i broke something in the suspension. when my steering wheel is at what would normally be straight, the left front wheel points to the right slightly. maybe a 10 - 15 degree turn. and when im driving the wheel naturally turns to the left about 20 degrees, but im going straight; the car seems to find a middle ground, with neither wheel pointing straight, but straight enough to make the car go straight. Also, when i make a left turn there is a grinding or rubbing noise of some kind. i did a quick check and nothing looked broken, but i know next to nothing about the steering system.
what i need to know is if i have just knocked my alignment horribly off, or if i broke something in the steering. all help is GREATLY appreciated.
Old Mar 19, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
either your alignment is off or your broke your control arm
Old Mar 19, 2006
Ashhole's Avatar
i was thinkin control arm, i just had to replace the one on the other side.
Old Mar 19, 2006
well when you get an alignment, they should be able to tell you what happened.
Old Mar 20, 2006
Ashhole's Avatar
we got under it as best we could tonight wihtout jackin it up, and so far dont see anythign bent or broken. we gonna jack it up tomorrow and get teh wheel off.
Old Mar 20, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
It may not look bent or broken, but it still could be
Old Mar 20, 2006
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
I'm not one hundred percent sure about the components used to adjust caster, but I believe that the caster, has been affected by damage to a part down that way, but hmm, I guess the only way to tell is like if we saw some pictures for comparasion, or if you brought it in.
Old Mar 20, 2006
Ashhole's Avatar
im hoping its just something along the lines of severly knockin the alignment off, but i very much doubt it. the slight grinding noises seem to ruin any hope of it being something simple.
Old Mar 20, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
tie rod cracked ....some bump
califcamper
Suspension
Apr 11, 2016 03:43 PM
SidCivic
Oct 3, 2015 06:00 AM
Styven Szastur
Sep 23, 2015 05:26 PM
kevfarr
Sep 18, 2015 02:28 PM
RIPSAW
Aug 16, 2015 12:14 PM
