Turbo Coolant lines
Old Mar 18, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
Turbo Coolant lines
Alright guys I have a custom turbo kit with a T25 turbo. My mechanic and good friend says its not necessary to run coolant lines to the turbo to cool it down. He said the hotter the better. I'm a little skeptic, should I run the lines or let it be.
Old Mar 18, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
if your turbo supports them, I'd install them.
This will definately prolong life of the turbocharger.
Some peeps at 240sx forums say it not necessary, but I doubt its resonable to skip on it.
Old Mar 18, 2006
Michalo187's Avatar
Abortion Survivor
yeah i installed mine also its a good idea
Old Mar 19, 2006
BigE19's Avatar
Alright my mechanic and I installed the kit without the lines were going to run it for abit and watch the oil pressure. Maybe in the future I will install the coolant lines
Old Mar 19, 2006
Havok2k1's Avatar
Wicked Pissah Admin
cooler air = condensed O2 = more HP
run the lines. It will make a difference when you need it.
Old Mar 19, 2006
tfnaaf's Avatar
BLDNPSI Mod
Why would you NOT hook them up its like $20 worth of parts to possibly save you $100's if not $1000's
Old Mar 20, 2006
turboengnr's Avatar
DONT PANIC
the hotter the better? I would not let them touch your car again.
Do they know WHY your turbo has coolant lines?
It is because the turbo will get soo damn hot that it will actually cook your oil. That sediment will plug the oil feed orifices and starve the turbo of oil. And that will cause it to destroy itself.
There is a very big difference between oil cooled turbos and water cooled turbos. Oil cooled turbos have a very large oil cavity that allows a much greated volume of oil to be inside the turbo at all times in order to cool it down. A Water cooled turbo only has a large enough oil cavity to lubricate the bearings. Thats all. The water cooled turbo does not have a sufficient volume oil cavity to cool the turbo down. And you will experience premature failure if you do not hook up the lines.
Old Mar 20, 2006
civic01vtec's Avatar
^ yeah dude........I wouldn't pay attention to your oil pressure, but check your oil temp.
Old Mar 20, 2006
BigE19's Avatar
Alright thanks for the input. I'll take a closer look.
Old Mar 20, 2006
eye_see_you's Avatar
let the devil out
INSTALL THE LINES!!!!! I had the m24 BB turbo and would not imagine running it without them as hot as it was at times. Your just asking for trouble
Old Mar 20, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Mechanic sounds a little off. That is one reason why I will do everything myself, if i can ever get the cash together. It is not easy being a student, maybe this summer i can save enough dough, maybe.
Old Mar 21, 2006
turboengnr's Avatar
DONT PANIC
i know what you mean about being a student.
CSUB costs $1100 per quarter plus books. Im spending around $1700-1800 per quarter for school. And i go 6 quarters per year (4 normal quarters, 2 intersessions)
Old Mar 21, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Water lines can be made for pretty cheap. size the ports on the turbo, you'll probably need some big banjo fittings or something (mine are big metric holes), get ones with hose nipples on the other end of the fitting, some 3/8" rubber (radiator or heater) hose, and a pair of nipples for the other end, cut the TB heater return and the feed and return inline with this. Probably can be done for 20 or 30 bucks.
No whining about school.... $1105 per CREDIT.
Old Mar 21, 2006
jackburton's Avatar
No whinning, just complaining.....sheez boilermaker, always with the negative vibes
What school do you go to?
Old Mar 22, 2006
turboengnr's Avatar
DONT PANIC
damn dude. wtf? $1105 per credit? You damn well better be making like $500,000 straight out of school.
Old Mar 22, 2006
Jap-Euro Fusion
Well, thats law school for ya.... I dunno about 1/2 a mil right away, but the money is good.
Old Mar 22, 2006
diskreet's Avatar
A hotter turbo will spool a bit faster but honestly do you think ball bearings like heating up to a few thousand degrees with something spinning 100000 rpm on it?
liagreenhalgh92
Jul 21, 2015 01:31 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
