post pictures of ur tsi set up
Old Mar 11, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
TURBO HEADS , ESPECIALLY TSI HEADS...PLEASE POST PICS OF UR TURBOED SETUP SO I CAN GET AN IDEA HOW IT LOOKS ...THANKS
Old Mar 11, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Sorry for quality, made by phone camera.
If you want to see something, then here it is:
Old Mar 11, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Oh man... please put a catch can in that breather line.
Old Mar 11, 2006
eye_see_you's Avatar
let the devil out
just a few
Old Mar 11, 2006
May be just to use separate lil' filter??
Old Mar 11, 2006
Jap-Euro Fusion
Another solution, but then you'll just spray all that crap all over the hood instead.
Vented catch can works, baffled catchcan with a slash cut for vac works better.
But regardless you don't want that oily crap going through the turbo and pipes... I can't honestly believe they sell the kit like that.
Old Mar 11, 2006
ncirom2003's Avatar
yea im just cutting and closing the pcv breather line, putting one of them lil 10 buck pep boys filters on.
anyways ill post pics in here for ya once im done but heres the setup as of now........
why doesnt everyone post up track times and dyno sheets too?? im hoping for 250whp and abour 13.3
Old Mar 11, 2006
Logan3024's Avatar
why must you nit-pick everyones setup?
Breather can isnt needed. oil doesnt "spray" out like you described
Old Mar 11, 2006
ncirom2003's Avatar
oh and personally one reason im putting that lil breather is because its a good indicator of blowby, if all of the sudden theres tons of oil, it means youve got excessive blowby (air/fuel blowing down past the piston rings creating higher crankcase preasure) and so its a good indicator of problems. its like the poor mans oil pressure gauge hahaha
Old Mar 11, 2006
Jap-Euro Fusion
Nit picking to some people is a good thing. Its ways of IMPROVEMENT. Thats a pretty simple thing to fix.
Second, if thats the way the kit comes, then how could I be picking on one individual person?
Third, what comes out of that breather is a fine mist of air, carbon **** and oil, its not exactly a solution you want running through the charge pipes. It makes a mess.
Fourth, if you want to run it like that, then do it. It makes little to no difference to me, but there are FAR better ways to do it.
Last, the PCV is still hooked up, so its not venting the bottom of the crank case under boost anyways, its only venting the head.
Old Mar 11, 2006
I'm confused now.
The stock air box has direct connection to the breather line.
Anyway you look at stock system it works exactly as TSI's.
Old Mar 12, 2006
ncirom2003's Avatar
yea but hes saying that its not nescessary and its not good to have that **** going into and through your turbo, plus it decreases the quality of air being taken into the engine so its better to not have it connected.
is true.
Old Mar 12, 2006
I see now.
Thanks.
+1 rep!
Old Mar 12, 2006
Jap-Euro Fusion
I'm confused now.
The turbo sucks a lot harder than the engine vac.
Also the stock system is rigged for one purpose, emissions. If you were to pull your IM off after some decient amount of miles, the inside of it would have a fair amount of crap in it. So it can be done like that, there's just far better ways it can also be done.
Old Mar 12, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
looks like it need a little clean up. Do you think???
Old Mar 12, 2006
haha, I see.
the pics were taken in the middle of winter. Li'l dirty, but it spring now, so clean up wont take long to come.
Also I'm **** as Mr.Clean about being super clean.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
