post pictures of ur tsi set up
Originally Posted by 03-Acura-1.7-EL
May be just to use separate lil' filter??
Vented catch can works, baffled catchcan with a slash cut for vac works better.
But regardless you don't want that oily crap going through the turbo and pipes... I can't honestly believe they sell the kit like that.
yea im just cutting and closing the pcv breather line, putting one of them lil 10 buck pep boys filters on.
anyways ill post pics in here for ya once im done but heres the setup as of now........
why doesnt everyone post up track times and dyno sheets too?? im hoping for 250whp and abour 13.3
Oh man... please put a catch can in that breather line.
Breather can isnt needed. oil doesnt "spray" out like you described
oh and personally one reason im putting that lil breather is because its a good indicator of blowby, if all of the sudden theres tons of oil, it means youve got excessive blowby (air/fuel blowing down past the piston rings creating higher crankcase preasure) and so its a good indicator of problems. its like the poor mans oil pressure gauge hahaha
Originally Posted by DIZZLE
why must you nit-pick everyones setup?
Second, if thats the way the kit comes, then how could I be picking on one individual person?
Third, what comes out of that breather is a fine mist of air, carbon **** and oil, its not exactly a solution you want running through the charge pipes. It makes a mess.
Fourth, if you want to run it like that, then do it. It makes little to no difference to me, but there are FAR better ways to do it.
Last, the PCV is still hooked up, so its not venting the bottom of the crank case under boost anyways, its only venting the head.
yea but hes saying that its not nescessary and its not good to have that **** going into and through your turbo, plus it decreases the quality of air being taken into the engine so its better to not have it connected.
is true.
is true.
I'm confused now.
The stock air box has direct connection to the breather line.
Anyway you look at stock system it works exactly as TSI's.
I'm confused now.
Also the stock system is rigged for one purpose, emissions. If you were to pull your IM off after some decient amount of miles, the inside of it would have a fair amount of crap in it. So it can be done like that, there's just far better ways it can also be done.
Sorry for quality, made by phone camera.
If you want to see something, then here it is:
haha, I see.
the pics were taken in the middle of winter. Li'l dirty, but it spring now, so clean up wont take long to come.
Also I'm **** as Mr.Clean about being super clean.
haha, I see.
