cleaning springs? grease them?
Drunken Master-7thgen Ninja
i picked up my s techs today. they are a little dirty. should i clean them and how? and should i grease them before i put them on next week? what do i grease them with? i did search. this is actually not a FAQ
just want to make sure cause i want to do this right! thanx!
Originally Posted by italy273
There is no point in cleaning them. they are just going to get dirty all over again. But if you NEED to clean them just some soap and water should do the trick.
What reason would you have to grease a spring? Springs dont normally have wear points so no need for grease. As for cleaning them I sometimes will pressure wash the strut/spring when installing new struts if the old struts were blown and have oil/dirt all over them.
well, i see signs of wear, like where one part of the spring rubs on the other, and the green rubber coating is off, its only on a little part, but if it rubs, i KNOW there will be noise of some sort, so im wondering if cleaning and greasing them before i put them on will help reduce the noise
Sep 26, 2023 06:44 PM
EM_WON
Jul 22, 2015 06:49 PM
Jul 12, 2015 11:54 AM
