New Parts installed
New Parts installed
Just put in the Seats (97 integra type-r 4-door suede recaros), steerring wheel (DC5), and shift boot (DC2). Still need to put in the DC5 rear seats. Here are some pixs. What you guys think.
The seats are out of a 97 integra type-r 4-door. The steering wheel and rear seats are from a DC5.
The gauge face is of of e-bay. reverse indiglo
other gauges are autometer-C2 gauges
the pedels are e-bay specials as well. I have a seat of mugen pedals but I only put those on for shows. I just leave those on for day to day. Had them on now for 3 years though.
I only hooked up the first Airbag wires. I left the second ones open with a 2.2 resistor. Hopfully I'll never have to find out if the airbag works or not.
I also modded it on the side to connect the cruse controls
That is a true DC5 steeing wheel. The install was easy. 2 screws and a bolt. Just had to mod the SRS plug cause our air bag is a 2 stage bag and the DC5 is a 1 stage.
The DC5R is a 1 stage, it is the Type R steering wheel, see the MOMO at the bottom, thats how you know. USDM RSX steering wheel is stage 2. You have to mod it in order for the bag to work. They have DIY to make it work on clubrsx, and also you just need to do some cutting for the cruise control to work.
isn't there a way you can check the airbag circuit w/o the airbag deploying?? like test points so you can check voltages or something?? the conventional way to check it is out of the question in this case....
Thanks guys. I have been trying to find somthing new to do with the interior and I think this stuff did the trick.
The engine runs great. Pulls hard as hell at 10psi. I have low boost at 10psi, overtake at 14psi and high boost at 16psi. Dont have time to dyno it or run it at a track cause I am in the process of moving to Louisiana.
No I painted it silver to match the car and then put a satin clear coat over it.
car has a basic street tune right now. Best i could do my self just to get me to and from work. I am trailering it to louisiana. when I get there I get it tuned.
There is gl@ss in my @SS...
