door panel remoale diy???
befre you link me to the diy. i am looking for dor removale with MANUAL windows not power as i am un able to remove the handle. thus un able to remove the frigging door. sigh
how do i get the bloody panel off :| im going nuts trying to remove that dan handle lol
picture would be perfect!!
tools:
door window crank clip removal tool
trim panel removal tool
flat head screw driver
pop off the piece to the door handle 2 screws located behind it remove them.
use the door window crank clip removal tool put behind the window crank pop the clip off. crank should just slid off next use the flat head to pop off the trim that you use to pull off the piece where the power window buttons are on a power car there should be 2 screws hold on the rear piece remove them and then use the flat head to pop that off...next the the trim panel removal tool and pop out all the pieces around the door panel and shzzaaam door panel is off
Originally Posted by spudracer326
you ahve to pop the jesus clip off it is inbetween the handle and the door use a screwdriver to pry it apart and pop it off. agfter that it should be easier to gert off
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
ballmich
Jul 9, 2015 11:59 AM
