ATF fluid
Old Jan 11, 2006
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
ATF fluid
Just got a quick question for everyone. How do you know when it's time to change the automatic transmission fluid. I think the color on my atf fluid is ok. But sometimes when I smear on it a white napkin, there's a slight dirt touch on it. I don't know if it's the stick or that there's dirt in the liquid itself. Can anyone please clarify how to go about this...??
Old Jan 11, 2006
manual says every 30k, but i do mine every 10k. it gets bad fast. when i first did mine at 18k miles, it was black with metal in it instead of red/pink.
Old Jan 16, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
^i must drive ultra conservative...
i just flushed mine at 60k
i checked my fluids and it was reddish brown...
Old May 22, 2006
lapchern's Avatar
lapchern is an unknown quantity at this point
what is "flushing" your transmission vs "changing (replacing)" your transmission fluid?
Old May 22, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
a flush is where you refill the amount of neccesary fluid, drive it around for a quick minute, drain then refill again. this requires 2x the amount of fluid.
changing/replacing - refilling = just like changing motor oil. but some folks do a flush along with motor oil as well.
i honestly believe flushes arent neccesary if you kept up your vehicles maintence
Old May 23, 2006
civics4everyone's Avatar
civics4everyone is an unknown quantity at this point
The only way to FLUSH is by a machine, which removes ALL the old fluid, usually costs like 59.99 at most shops, problem is most shops dont use honda atf they use dexron. Id rather them not touch my car! Only honda or select other shops use genuine fluid. Even honda dealers dont use flush machines they just drain and fill several times which will get 90% of the fluid changed. Honda fluid is way too expensive to use in a flush machine thats why it isnt usually done. 12 quarts x 6.00 $ = 60$ in just fluid not labor.
sf3r8z
Apr 19, 2016 01:53 PM
Raiool
Oct 1, 2015 10:42 AM
ken4444
Sep 30, 2015 07:37 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
